Forum: Music discussion
Topic: Virtual DJ mixing - automix
Hello
I have a list of songs for a wedding. They are dance songs and I am not very good mixing dancing songs.
Is there a way that Virtual DJ automixes? I tried the 'automix' thing in the playlist section but it sounded awful. My mate pressed my keyboard by mistake the other week and it mixed in another song really well! I dont what he pressed, but are there any shortcuts on the keyboard to mix in songs?
Thanks
geposted Mon 21 May 12 @ 10:42 am
Sort your playlist by BPM. You can also edit the automix Entry and Exit points by: right clicking a track --> BPM --> Manual Edit --> Automix tab. Also make sure your CBG is lined up (right clicking a track --> BPM --> Manual Edit). I usually line the first kick up with the first bar (big dot) because thats what i like to target my loops and effects on.
I think the keyboard shortcut is ctrl + space. This just enables/disables automix. Your best bet is to sort (low to high) and listen to them. When something sounds bad, adjust the automix entry and exit points. Good Luck!
gente quando eu abaixo todo o volume da musica do deck A do virtual dj a musica para volta do começo como faço pra ela continuar tocando???
This is the English Language Only Forum. You need to repost your question in English or use the appropiate language Forum https://virtualdj.com/forums/
When people I lower the volume of the music business to make a deck A Virtual DJ Music Back to the beginning How to Do SHE Continue Playing?
I am not sure if understand correctly. But you could use a Cue point at the beginning of the track where you want to quickly restart from.
let's try again
When I lower the volume or turn around the crossfader all the way right, the music of the deck 1 and back to the beginning, how do I keep playing it even with the volume at zero??
It's still difficult to understand what you're asking.
Why don't you post in the Portuguese forum?
From what you say, it seems like there's some sort of fader start happening. Which skin are you using? Are you using a controller?
não sei usar o forum, estou usando um computador é isso que acontece é um fader start com virtual dj
