I just installed the dj console rmx with virtual dj 5.2.2
I can load the tracks into the program with no issue but when I attempt to play the track I do not hear any sound.
The program looks as if it is trying to play (scrolling song) but no audio is heard.
Sound does work from all my other programs so the issue is isolated.
Specific Info
Windows 7 Ultimate x64
PC > AMP > Speakers
Hercules DJ Series Control Panel
Audio mode is ASIO (WDM is not selectable)
Package: 4.HDJS.2009
Firmware: 1.1.4.31
Driver: 4.7.5.0
DJ API: 2.0.18.7
CPL: 2.0.5.1
Specific Info
PC > AMP > Speakers
Firmware: 1.1.4.31
Driver: 4.7.5.0
DJ API: 2.0.18.7
CPL: 2.0.5.1
geposted Fri 01 Jun 12 @ 3:22 pm
Well the RMX is an external device...
When you play music in VDJ with the RMX connected as your output, then the music will be output through the RMX - not your computer.
You need to connect your speakers to the output of the RMX to hear something!
geposted Fri 01 Jun 12 @ 4:40 pm
The Hercules DJ Console RMX is connected to the computer with the USB cable provided.
Also the drivers that came with it were installed successfully.
I want it to output using the computers output.
geposted Fri 01 Jun 12 @ 6:08 pm
The whole idea of using an external mixer/sound card combo unit like the RMX is that the sound does not come out of the computers sound card and speakers (which are usually low quality rubbish).
What you have is working correctly - the sound is coming out of the RMX.
Plug the output of the RMX into your audio system and you will hear sound.
geposted Sat 02 Jun 12 @ 4:11 am
I will hook the unit directly up to the amp as you have described.
Thank you very much for your quick responses.
geposted Sat 02 Jun 12 @ 9:19 am
If you want to output the master sound through your computer's speakers for practise at home, then please see the following FAQ page:
https://virtualdj.com/wiki/VirtualDJ%20LE%20sound%20through%20computer%20speakers.html
geposted Sat 02 Jun 12 @ 2:33 pm
hi
i have vdj 8 i have audio with music track but not with video, the video plays fine but no sound
geposted Fri 05 Jun 15 @ 3:34 pm
jungleiam wrote :
hi
This is a very old thread regarding a completely different version of Vurtual DJ
I would recommend starting a new thread with your issue. Make the subject descriptive to your problem.
I'm confused with your question as well. I think your saying you can hear audio with and audio only track, but no audio with a video track. When you open a new thread, please be clear in your question.
geposted Fri 05 Jun 15 @ 4:33 pm
