Forum: VirtualDJ Plugins
Topic: SBDJ StereoChannel
Hi,
https://virtualdj.com/addons/14832/SBDJ_StereoChannel.html
A simple audio plugin that quickly allows a user to select an individual channel from a stereo file (or to reverse them) to be used on both stereo channels. Apparently this functionality is useful to some karaoke users.
Regards,
Scott
geposted Mon 04 Jun 12 @ 2:55 pm
Thanks Scott, hope this one is easier to use then the one I have....
SBDJ,
This pluggin is extremely useful for me, because I have many karaoke DVD files (.VOB) that is recorded on 2 audio tracks (1 with vocal and the other one without). I can use VLC media player to change the audio track to 2 to turn off the vocals, VLC is not a karaoke player. If this is able to do that, I'll purchase the pro verison ASAP. Can you tell me if this will work the way I want it to?
Thanks
Yes.
Just tested this and it's magnificent.
Options:
Normal stereo
Reversed channels stereo
Left channel only mono across both channels
Right channel only mono across both channels
Seems to be just what you are looking for.
Thanks for this Scott, really handy for some stereo 60s tracks in some situations.
Keith
I could see that if it had an option to combine both channels into a single (or double) mono signal.
Thats great, thank you for the feedback guys...
FOR MAC?
I have been looking for documentation for SBDJ StereoChannel, but haven't had any luck. Is there a way to look at a plugin to see what the options are?
What I want to do is make set three custom buttons:
Left channel mono
Right channel mono
and Stereo
I tried using the audio settings but "Deck 1 | (Soundcard) | Chan 1 (mono)" only goes out to one speaker.
I installed SBDJ StereoChannel and set a button to
effect 'SBDJ StereoChannel' active toggle
But that only seems to toggle between "Left" (Chan 1) mono in both speakers and stereo. I could not figure out how to get it do "Right" (Chan 2) to both speakers.
I am a karaoke host and this is for karaoke multiplex play.
Thanks!
Left channel mono
Right channel mono
and Stereo
Thanks!
This may help:
