Forum: Greek Forum
Topic: μια βοηθεια σας παρακαλω! - Page: 2
pffff den bgazw akrh oute apo to eikonidio tou hxou oute apo pou8ena allou...tpt de leei... katebasa utilities kai drivers apo ton kataskeuasth pali tpt den egine...!!!:@
Gia deka lepta einai
Δεν κλεινει το virtual κανονικα
djdad ekana thn 1h lush alla tipota...ebala ta akoustika panw sthn e3wterikh karta hxou usb epele3a auto p eipes alla tipota... ti kanw la8os???
Dokimase na valeis tin USB karta ixou san default....
Deksi klik sto eikonidio me to ixeio (katw deksia) -- Properties.. Epelekse tin USB karta ixou kai valtin san proepilogi, kai dokimase ksana
Apo ta ixeia tou ypologisti akous to master KAI tin proakoustiki ?
An den petyxei auto, kane to eksis...
Anoikse tin Home Free..Sto Config-->Sound setup epelkse MORE, na sou anoiksei to allo SOund setup menu.
Ekei epelekse..
Inputs None
Outputs..Headphones
Sound card...2 sound cards. kai dipla sto panw parathyro epelekse tin enswmatwmeni karta tou ypologisti kai sto apo katw parathyro tin USB.
Pata OK kai kleise tin Home Free.
Meta anoikse tin pali
kai pali tipota ta dokimasa kai ta duo...apelpisia.... tsampa thn agwrasa thn karta hxou m fenete...
egine tpt telika???
kalipsera sas... signomi gia tixon lathoi !!den skero ama eimai sto sosto meros alla eimai kainourgios kai oligon mperdemenos..exo agorasei hercules dj control air edo kai ligo kairo kai itan ola mia xaxa alla ksafnika apo exthes den mporo na tin sindeso sto laptop .molis balo to kalodio xtipaei ''ntit nti nti ''astamatita kai den kanei tipota. mou bgazei ena thaumastiko... eimai kai ligo asxetos dioti tosa xronia olios mathimenos..sas parakalo an mporei kapios na me kathodigisei.ti fatiei to laptop?i i i to hercules?
euxaristo re paidia prokatabolika
Kalispera!Tha ithela na me voithisete se ena provlima pou exw entopisei.Exw tin Hercules Dj Control Air kai paizw me to VDJ 7 pro.Enw paizw kanonika loipon xwris kanena provlima,ksafnika arxizoun na akougontai kati parasita kai apo ta akoustika alla kai apo ta ixeia(master output).Giati simvainei auto?Dokimasa polles fores,to ekleisa,evgala tin kosnola apo to laptop,ekana epanekinisi kai arketes fores epilithike.Alles fores omws sinexise se megalo diastima.Mipws ftaei to VDJ pro?Giati me to DJuced pou eixe mesa i konsola,den paratirisa kati tetoio.Sas parakalw voithiste me!!
To pio pithano einai oti i cracked version pou xrisimopoieis dimiourgei ola auta ta provlimata.
O thoryvos pou erxetai meta apo kapoio xroniko diastima einai mia "gnwsti" cracked version.
H lysi vrisketai edw .. https://virtualdj.com/buy/
Euxaristw poli!Tin esvisa ekeini tin ekdosi entelws giati mou evgaze ''error 8'' kai ekana install tin teleutaia ekdosi 7.5.Tha deiksei o xronos an eftaige kati apo auta.As elpisoume na min kanei tipota paromoio!
Ούτε λόγος δηλαδή (έστω για τα μάτια του κόσμου) για νόμιμη έκδοση... :P
Και η τελευταία έκδοση ΔΕΝ είναι η 7.5
Καλησπέρα σ ολους.
Ο εξοπλισμος μ ειναι 2 cdj350 1 μεικτης Nuo 3 by ecler.
εχω αγοράσει πρόσφατα το virtual dj physical box.Το προβλημα ειναι το εξης:
(να σημειωσω οτι το χρησιμοποιω για επαγγελματικη χρήση)
παροτι έκανα προσφατα φορματ το προγραμμα κολλαει δηλαδη δν παιζει ο ηχος ενω φαινεται να δουλευει κανονικα στο screen αλλα
δεν ακουγεται μουσικη.σημερα εκανα κατα λαθος μια αλλαγη στη ρυθμισεις screen δηλαδη αλλαξα την αναλυση(την ωρα που κολησε) κ συνεχιζε να παιζει χωρις να κανω επανεκινηση το προγραμμα.Αλλα μετα απο λιγη ωρα παλι τα ιδια.
Ευχαριστω εκ των προτερων.
Mporo na do tin agora sou, dilose omos to serial number sou sto profile sou ekei pou leei "licenses"
https://virtualdj.com/users/edit.html
Gia to problima sou den mporoume na poume xoris na kseroume tis rythmiseis sou kai se ti katastasi brisketai to pc sou genika.
Gia to deutero ksekina apo edo :
http://www.thesycon.de/eng/latency_check.shtml
https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
Gia to proto mporeis na postareis kapoio screenshot apo to sound setup sto virtualdj
Να συμπληρώσω επίσης οτι καλό θα είναι να κάνεις και αναβάθμιση στο firmware των CDJ-350 στην τελευταία έκδοση αν δεν το έχεις κάνει ήδη...
να συμπληρωσω οτι παντα ακουγεταιτε ενας ηχος "Χρατς" καθολη τη διάρκεια του κομματιου
δλδ παραλληλα με το κομματι.δεν ξερω πως αλλιως να περιγραψω τον ήχο κ δν ξέρω αν βοηθάει που το αναφέρω.
ευχαριστώ για το ενδιαφέρων
καλησπερα
αγοασα το προγραμμα για το ipad αλλα δεν μου ανοιγει μπορει καποιος να μ βοηθησει
ευχαριστω
Παιδια θελω την βοήθεια σας! !! Εχω 2 αυτοενεισχυομενα ηχεία mackie thump 12a τα οποία την τελευταία φορα που επαιξα τα red clip αναβοσβήναν σε πιο χαμηλή ενταση απο τις άλλες φορες...τα ξανα δοκίμασα και παλι το ιδιο...
98%
