Ok I've bout the IDJ3 got it set up and from the outside it looks and feels great but the more I play around with it the more Im seeing I guess the word to use is problems, my question is
A) Is the IDJ3 a viable option for Learning to DJ (IE Scratching, Beat juggling, mixing)
B) is this deck configurable to the point where the jog wheels will act more like the real thing
C) If the IDJ3 isnt a sufficient learning tool then what is?
keep in mind we're in a recession and while I'm not poor I'm cheap as hell and don't want to buy something just because it has a popular name I need good beginner hardware
geposted Sat 30 Jun 12 @ 4:03 pm
ISSUE WITH IDJ3
BROKEN SOFTWARE DISK
DEVICE WON\'T CONNECT WITH ANY LAPTOP/DESKTOP COMPUTER
CONNECTION ERROR ISSUES
IM FED UP DJ[IDJ3 COLLECTING DUST]
NO HELP IN SIGHT
SEE VIDEO LINK BELOW
http://youtu.be/hSz7JspwPJY
NO HELP IN SIGHT
geposted Sat 05 Jan 13 @ 12:48 pm
Go to your download centre and it's there, you don't need the disk to install VirtualDJ.
If you need drivers for the unit they will be on the Numark website.
Keith
Keith
geposted Sat 05 Jan 13 @ 12:55 pm
I just got the idj3 and i noticed you cant do any affects on the deck, you have to click on virtual dj, is the idj3 compatable with other mixers?
geposted Sun 06 Jan 13 @ 10:02 pm
barrynel wrote :
ISSUE WITH IDJ3
IDJ3 has no native drivers. It is a plug n play device. No need to install anything. The drivers you see in numark.com are for Mixvibes software only.
In case the device is not properly detected , read here.. http://www.virtualdj.com/wiki/midinotdetected.html
All you need is the LE version of VirtualDJ which is available on your Download Center.. http://www.virtualdj.com/download/updates.html
Just make sure you use the correct installation file with the correct serial, as i see 2 of them registered to your account.
geposted Sun 06 Jan 13 @ 10:37 pm
The virtual dj works, just when you go to config the idj3 with virtual dj nothing is being recognized. Its like its not even plugged into my laptop.
geposted Wed 27 Mar 13 @ 5:51 pm
WHAT IS THE BEST LAPTOP FOR IDJ3 AS FAR AS PROCESSOR SPEED
geposted Fri 20 Sep 13 @ 10:31 am
0
WILL A 2.3 BE FAST ENOUGH BECAUSE A 1.8 ISNT
geposted Fri 20 Sep 13 @ 10:40 am
Please don't type messages IN ALL CAPS - Please read the forum rules.
Before doing anything, make sure that your current computer has been optimised for DJ performance: http://www.virtualdj.com/wiki/Performance%20Issues.html
The issues that you are experiencing may be due to the fact that your computer is not optimised and/or is being slowed down by unnecessary software running in the background. Available memory (RAM) and the operating system (If Vista) may also be part of the issue.
In general, 2Ghz or faster dual-core Intel CPU with 4Gb RAM would be recommended for best performance.
geposted Fri 20 Sep 13 @ 11:46 am
Installed Idj3 on my laptop but someone stepped on my screen. Trying to load on new laptop but will not let me get past entering my serial number. Entered numerous times but keeps saying invalid? ??
geposted Sat 11 Jul 15 @ 6:58 am
