Forum: Old versions
Topic: USB 3.0 - DJiO - Other options? - Page: 1
Replaced 2 notebooks with new ASUS Win 7-64 Bit -16 GB Ram -SSD & 4 USB 3.0 ports only. As you can imagine they do not work, a week of searching the internet has led to this post. Is there a USB 3.0 external sound card out there or should I drop to firewire? Numark says "it won't work". I have thought of a powered USB hub that has 2 USB 2.o ports but will probably get blue screened on that too. ANY SUGGESTIONS ARE NEEDED. Got 2 weeks till my next gig. Thanks in advance for the help.
geposted Thu 05 Jul 12 @ 5:56 pm
I have an Asus with your same specs you mentioned expect that I only have 1 USB 3.0 and 3 USB 2.0 ports. USB 3 is backwards compatible with older USB versions, I plug in USB 2 peripherals into it my Blue USB 3 port all the time without any problem. Right now as a matter of fact I have a Microsoft 2.0 USB laser mouse plugged into it and it works great.
Are you sure you installed the correct numark driver to your system? Have you tried plugin in other USB2 devices like a mouse or keyboard?
Check your device manager and make sure you don't have any hardware conflicts or missing drivers, if everything seems fine call Asus because it seems you have some driver issues, I know for a fact that USB 3 port will accept your older 2 peripherals. I just plugged in more USB 2 stuff into my my blue USB 3 port and it worked. Logitech usb 2.0 keyboard WORKED, Epson Printer USB 2.0 WORKED, Microsoft laser mouse UBS 2.0 WORKED and Native Instruments Auio 2 DJ sound card WORKED!
I get everything to work but the DJ Io. It bluescreens when trying to install the latest driver for Win 7 and reboots as if nothing was installed. It's very odd, being a 20+ year PC tech I would think it would work with no problem, however a call to Numark support said it will not work with usb 3. no other answer just no. So I am debating about buying firewire external cards or just run off spid until something comes out that says works with USB3. I mean the little DJ Io's are ok but I am not convienced they are solid pieces of equipment. I do have the original disk that came with the boxes, I could try that I suppose but you would think the latest driver from Numark would be what you wanted.
Sounds to me as if Numark are just too lazy to fix the issue.
On the other hand, USB3 is still quite fresh out of the blocks.
You could go here and complain http://community.numark.com/numark
There are Numark staff there.
The lesson here perhaps is to buy an interface from a more professional company.
Not sure what you're basing your comment on groovin', but I think it's uncalled for as only a few soundcards work with usb 3.0.
I guess that USB3 -compatible soundcards will not come very quick. There's just no need for. The amount of data a soundcard has to process can be handled with ease by by an USB1-card. I can only imagine that a controller will send so much data that USB3 is required, but not in a near future.
USB ports are supposed to be fully backward compatible with USB2 devices, however in my experience it's sketchy at best.
When I had the Acer Iconia I found that on USB3 the denon Asio drivers had no audio, however it works fine on the Toshiba Ultrabook.
Keith
So it sounds to me like the computer manufacturer must ensure that the latest Intel USB3 Root Hub Driver works. WARNING!!! I TRIED UPDATING MY USB ROOT UB DRIVER FRON INTEL, MACHINE BLUE SCREENED ONCE AND Went to recovery mode...DO NOT TRY THIS!!!!
Can anyone give me a list of "good" USB Cards that will work or is the opinion that I should just go to firewire and wait. I know the DJ community is not on the bleeding edge of hardwar, you had albums, cds, mp3, computer not computer upgrade issues. So I don't forsee anyon putting out a USB 3 compatible card for a while. Yeas it should be backwards compatible but it isn't. I also agree that 99 buck plastic sound cards are entry level but they served me well. I may try to run one with power to it instead of trying to power from USB if that doesn't work....firewire (unless someone gives me a good USB alternative) here I come.
Just my opinion: I've had great results with a FreWire-card (M-Audio FW410) But I think your laptop-manufacturer is the first to blame. Your laptop should recognize that you're using an USB2-device, but it looks like it doesn't.
See if you can borrough a USB-hub and put that between your IDJ and your laptop. If the hub can handle the step-down your controller might work.
I'm basing my comment on USB3 being backwards compatible with USB2 devices, so it's likely down to Numark's driver.
Also, some Numark products do work with USB3 (the NS6 for example) - this has been stated by Numark staff on their support forum.
It is definately the driver. I wonder if another ASIO would work with it? I can get it plugged in and it tells me what it is in device manager, it just bluse screens with that ASIO driver everytime
Unfortunately not. ASIO-drivers are soundcard-specific.
Have you tried to use the WDM-drivers? Select the Numark in Soundcard instead of the ASIO-drivers.
I'll try. Is there any external card out there that we know works with USB 3??
Nope... will not work with 3.0.
****ASKING VIRTUAL DJ FOR HELP TO FIND A USB EXERTAL SOUNDCARD FOR US USERS!!!
MAGAGAR80 wrote :
Native Instruments Audio 2 DJ sound card WORKED!
Native Instruments Traktor Audio 2 does NOT WORK. Learned that 100 lesson today. BE ADVISED ALL EXTERNAL SOUND CARDS AND/ALL IN ONE CONTROLLER UNITS MAY NOT BE COMPATIBLE WITH YOUR AUDIO HARDWARE. I have an ASUS G75 with only 4 USB 3 ports...no firewire..no old usb2 ports. Heck USB 3 has been out since 2010. Anyway you one ticked off DJ that is going to have to DJ from the freaking onboard card. May as well just make a playlist and hit play.
What USB3 host controller does your machine have out of interest?
I have the DJIO and a HP envy 14 64BIT and the IO works through my USB 3 port with no problems at all, also the DEEJAY TRIM 4&6 works fine through it as well.
Dont know if I am lucky or you have bad drivers for your USB3.
Ian
It's to do with the chipset on the USB3 it seems.These can change between manufacturers.
All seems a bit hit and miss at present but the principle is that USB2 devices SHOULD WORK on USB3 connections.
Keith
You should tell Numark....
Apparently they've been saying it won't work!
67%
