Gia sas paides...Skeftomai na agorasw kati anamesa se:
Mixvibes U-MIX Control Pro http://www.soundimage.gr/product.php?id_product=767
ή
Hercules Dj Control Air http://www.technosound.gr/index.php?dispatch=products.view&product_id=1262
ή
Hercules DJ 4Set http://www.hercules.com/gr/DJ-Music/bdd/p/146/hercules-dj-4set/
Ta erwtimata kai oi anisixies mou einai ta e3is..
1)Ginete na sindesw to mixvibes me to Virtual dj7?An ginete meso mappers o sinxronismos 8a einai kalos h...?
2)Gia to Hercules Control Air to mono mou provlima einai oti exei e3odo mono ena jack
3)Den eimai kai sigouros alla to Hercules dj 4set exei mono 2 kanalia e3odou...
Genika eimai sxetika arxarios me to olo 8ema kai 8elw na dia8esw mexri 220e gia na parw kati...Ti 8a mou protinate eseis anamesa se ayta ta 3 alla kai genikotera opia protasi iparxei dekti.. :)
ή
ή
geposted Wed 25 Jul 12 @ 5:51 pm
Κοιτα και το NUMARK - MIXTRACK PRO ειναι στα 200ε και ειναι αρκετά καλό για ξεκίνημα.
geposted Wed 25 Jul 12 @ 7:12 pm
exw tin hercules dj4set.......einai para pl kalh kai a3izei ta lefta ths....exeis 4 deck kai se boh8aei pl....nai file m exei 2 e3odous...!
geposted Thu 26 Jul 12 @ 2:11 am
h hercules exei koumpi master tempo?
geposted Thu 26 Jul 12 @ 4:20 am
Anamesa sthn mixtrack kai tin umix conrol pia 8a protinate kai giati?
geposted Thu 26 Jul 12 @ 7:42 am
mixtrack.....dagkwto
geposted Thu 26 Jul 12 @ 7:54 am
Na koitakseis kai tin American Audio VMS2. Exei ola ta inputs-outputs pou mporei na xreiasteis.
geposted Thu 26 Jul 12 @ 9:36 am
Anamesa se mixtrack pro kai vms2 ti 8a legate?
geposted Fri 27 Jul 12 @ 9:30 am
εγω θα επέλεγα τη vms2 μιας και είχα την vms4 και ήταν πολύ καλή.. αλλά είναι στα 259ε με μια πρώτη ματιά που έριξα.
geposted Fri 27 Jul 12 @ 9:36 am
και εγω θα διαλεγα την vms2 ....ειναι πολυ καλη επιλογη
geposted Fri 27 Jul 12 @ 10:45 am
Re paidia eimai se megalo dilima...mixtrack pro h vms 2?
to dilima mou einai an a3izei ta lefta parapano to vms2 se sigrisi me to mixtrack pro kai episis an einai too much gia 1o midi....
episis ligo ta vismata mou tin spane pou to mixtrack pro dn exei input...
episis allia mia erotisi gt dn exw doulepsei pote me enisxiti,douleva sinexeia me monitor,,gia na sindeseis amp se midi conntroller prepei na exei eisodous input swsta?
edometa3i 8elw na pe3w se ena partaki to savvato kai den exoume ixia gt lipei to palikari pou ta krataei kai prepei na nikiasoume pezei na 3erete kana magazi pou nikiazei e3oplismo a3iopisto kai oso to dinaton oikonomiko?
geposted Mon 30 Jul 12 @ 2:43 pm
ο ενισχυτής συνδέετε στο Output του κοντρόλερ, όχι σε input. :)
δεν ειναι καθόλου υπερβολή για πρώτο κοντρόλερ η vms2, θεωρώ πως είναι πολύ καλή αρχή.
geposted Mon 30 Jul 12 @ 3:41 pm
INPUT= Είσοδος
OUTPUT= Έξοδος
Τώρα πώς στην ΕΙΣΟΔΟ μιας κονσόλας εσύ θες να συνδέσεις την ΕΞΟΔΟ του ήχου σου;;; Τι να σου πω;;;
Όπως είπε κι ο Τάσος από πάνω, τόσο οι ενισχυτές, όσο και τα αυτοενισχυώμενα ηχεία συνδέονται σε ΕΞΟΔΟ του μίκτη/κονσόλας κτλ
Επίσης για να σε βοηθήσω:
Κάθε ΕΞΟΔΟΣ ενός μηχανήματος συνδέεται στην ΕΙΣΟΔΟ ενός άλλου.
Έτσι στον ενισχυτή σου, αφού στην ΕΞΟΔΟ βάζεις τα ηχεία, η είσοδος παραμένει ελεύθερη. Και επομένως στην ΕΙΣΟΔΟ του ενισχυτή πρέπει να βάλεις την ΕΞΟΔΟ ενός άλλου μηχανήματος (του μίκτη/κονσόλας δηλαδή)
Τέλος, αν έχεις την οικονομική δυνατότητα ξεκίνα με κάτι καλό. Είναι προτιμότερο να πάρεις κάτι καλό που θα σε βγάλει για κανά δυο χρόνια, παρά να πάρεις κάτι μέτριο που θα σε βγάλει μερικούς μήνες και μετά θα θέλεις να το αλλάξεις.
Το καλό θα έχει και καλύτερη μεταπολητική αξία από το μέτριο, που μπορεί να μην έχει και "καθόλου"
OUTPUT= Έξοδος
geposted Tue 31 Jul 12 @ 1:53 am
Τωρα παρατηρησα στα περισσοτερα site oti to mixtrack pro erxete me traktor LE...3erete an pezei kana magazi stin a8ina pou na to dinei me Virtual Dj LE gt psaxnw kai den vrsikw tipota...
http://www.numark.com/virtualdjleupdate an katevasw ayto 8a borw na doulepsw to mixtrack me virtual dj?
episis alli mia erotisi .. to shift key ti akrivos kanei gt idi oti h vms to exei eno i mixtrack oxi...
geposted Tue 31 Jul 12 @ 5:07 am
1.
Δυστυχώς πολύ δύσκολα θα βρεις στην Ελλάδα (και στην Ευρώπη) τόσο τη Mixtrack όσο και κάποια DENON με συνοδευτικό πρόγραμμα το VirtualDj. Κι αυτό γιατί οι εταιρείες διανέμουν διαφορετικά συνοδευτικά προγράμματα με βάση τη γεωγραφική περιοχή.
Για παράδειγμα η DENON MC3000 και MC6000 πωλούνται στην Αμερική ΜΟΝΟ με το VirtualDj LE και στην Ευρώπη-Ασία MONO με το Traktor LE.
2.
Όχι. Αυτό είναι ένα update. Για να δουλέψει θα χρειάζεται serial number που εσύ δεν θα έχεις αφού δεν το είχε πάνω η κονσόλα σου.
3.
Το SHIFT κάνει (σχεδόν) ότι και το SHIFT στο πληκτρολόγιο.
Επιτρέπει στα περισσότερα πλήκτρα και knobs να έχουν διαφορετικές λειτουργίες ανάλογα με το αν είναι πατημένο το SHIFT ή όχι.
Για παράδειγμα:
HOT_1=hot_cue 1
SHIFT+HOT_1=delete_cue 1
SYNC=sync
SHIFT+SYNC=pitch_reset
κτλ κτλ
2.
3.
Για παράδειγμα:
HOT_1=hot_cue 1
SYNC=sync
κτλ κτλ
geposted Tue 31 Jul 12 @ 5:30 am
na se rwtisw kati akoma...to vms 2 den exei filter knob etsi? h genikotera gia effects..
geposted Tue 31 Jul 12 @ 6:42 am
filter den exei alla ta effects (epilogi, ri8misi toy effect slider 1 kai effect slider 2) ginetai apo to encoder poy brisketai sto kentro kai ta 4 koympia giro toy
geposted Tue 31 Jul 12 @ 7:32 am
paides gia ayto tosetaki ti exete na peite?To party 8a gineie se anixto xro giro sta 50 tetragonika me toixous omws gyro gyro..
geposted Wed 01 Aug 12 @ 5:03 am
2x250W RMS είναι υπεραρκετά (και με 2Χ150 θα κάνεις δουλειά)
Νοίκιασε 2 αυτοενισχυόμενα 12ιντσα ή μεγαλύτερα και θα είσαι κομπλέ.
geposted Wed 01 Aug 12 @ 5:13 am
ta aytoenisxizomena exoun kaliterh apodosh apo ta apla karfomena se amp?
geposted Wed 01 Aug 12 @ 5:15 am
