Forum: Old versions
Topic: Emergency! Can't access options!
I have an American Audio VMS2 that came with VirtualDJ LE. When I go to CONFIG to set up VDJ to play through my controller, all it does is say I need to buy Pro Full. I'm not trying to get to any really advanced options, I just can't get to the options PERIOD. The DJ controller does nothing if I can't switch it in the settings, and Virtual DJ LE is supposed to let you use the MIDI controller it came with. I'm supposed to show up somewhere and play very shortly. Please help!!!
geposted Tue 14 Aug 12 @ 6:49 pm
VirtualDJ LE is free limited software and doesn't have any configuration options (Except normally basic sound configuration to allow you to choose the sound card built into the controller.) Please see: https://virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
Make sure that you have the latest drivers and firmware for the VMS2 installed from the manufacturer's website along with the most recent version of VirtualDJ LE and it should work OK.
You may also need to configure the sound card built into the VMS2 for 4 channel audio on Mac. Please see: https://virtualdj.com/wiki/Configure%204%20channel%20audio%20on%20Mac.html
I had my trial expire before it was supposed to...in the ABOUT box it said 5 days used and that was yesterday, today I was back to the LE version and lost all my playlists...how can I get this fixed? i want the rest of the trial, and if possible my playlists back...thanks
