Forum: VirtualDJ Plugins
Topic: sound effects dont appear in the virtual dj program
hi i just downloaded some effects to use em with my virtual dj program and they cant be used they are not even shown in the effects wheel. i checked the docs/vdj folder and all the dll files are there but they arent in the main program. please someone help me. Thank you
geposted Thu 23 Aug 12 @ 8:36 pm
This is because you are using VirtualDJ LE, which is free limited software and does not support using custom effects, skins, etc. except during the time limited trial of the full VirtualDJ Pro.
To be able to use custom effects and much, much more, you will need to upgrade to the full VirtualDJ Professional at a discount: http://www.virtualdj.com/buy/index.html
Please see: http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
do they also work with the virtual dj pro basic?
If your gonna upgrade just go "Full Pro", that version is limitless and you won't be wasting money on versions that won't work for you......
