Forum: Old versions
Topic: Soundcard problem with Numark N4 controller
Getting the following message when i try to work as normal using my laptop with my N4:
"Error in the sound driver (DirectX/WDM): Your soundcard is not connected or the settings are incorrect".
Any suggestions on the fault & how to rectify please?
geposted Sun 16 Sep 12 @ 10:14 am
Support staff wrote :
This means that it's sound card is not configured correctly.
Please see: https://virtualdj.com/wiki/N4.html
Also, DirectX/WDM means that you are using a Windows PC (Or perhaps a Mac with Windows running via bootcamp?) - For PC related problems, please ask in the correct forum PC technical support: https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
Ok, thanks for the quick reply. Yeah it's a laptop with Windows XP. I've altered the settings as you advise , now it seems to be working correctly.
I'll see if it all works fine as before next time i'm at work (Monday night).
I've updated my back up CD's just in case.
Thanks for your help.
hello, having problem with my n4 since yesterday..everthing was ok 5 days ago since the last time i used it. no audio is coming out ( on RCA's and headphones ) volume indicator light is not is moving. few minutes after i connect the unit on my laptop a click sound comes out from the speakers ( through RCA ) and headphones ..tried using and external soundcard and the sounds works perfectly...im using VDJ LE with it..
tried also turning on just the unit and im still hearing that click sound from my output speakers and my headsets..sound goes also up when i turn the volume bottom up and down when I turn it down.. using windows 7 64bit...everything was ok since i started using the set..it is also well cared and it has even has its own bag..
Hi im having a problem with my N4. The crossfader wont work and the cue button on deck 2and 4 wont work. Help please. FYI just got the N4 and just cant get it to work properly.
