Forum: VirtualDJ Plugins
Topic: [Update] RollIt V3
Hello!
I just wanted you to share my new update with version 3.
NO VST ANYMORE!!!
If someone of the Moderator could please be so kind to change the Effektname to "RollIt" because VST is now wrong.
The effeckt is now based on the SDK V6 and complet rewritten. After a bugfix-feedback i'll add the version for mac Users.
Rollit simulates an advaced Roll of a Pioneer CDJ 400. Some know the effect from the beginning of "Swedish House Mafia - One"
http://www.virtualdj.com/addons/13517/_VSTi__RollIt_.html
Regards, C.Hackl
geposted Wed 17 Oct 12 @ 1:25 am
Update 3.1:
added the quantised Loop Length like in Version 2
Released MAC User Version
Regards, and much fun with it,
C.Hackl
Chackl wrote :
Update 3.1:
C.Hackl
Very nice! thank you for the Mac version. I will try It and let you know.
What are the default settings for the effect RollIt again please?
Default is:
Mix Slider 50%
Speed Slider 50% - Original Speed
Length Slider is 50% - Loop half beat
Quant is off
sync on CBG is off
Extended Rage is off
Regards
Chackl wrote :
Default is:
Mix Slider 50%
Quant is off
sync on CBG is off
Regards
Thank you very much.
is there a way to map the effect so that when you activate it, the speed slider automatically changes to 50% (original speed) ?
try this:
effect 'rollit' active & effekt 'rollit' silder 2 50%
regards
tried it...doesnt seen to be working man
there is a simple spelling mistake
effect 'rollit' active & effect 'rollit' silder 2 50%
oops ^^
it happens to often to me :P - sorry for the mistake
fixed the spelling and still no luck haha
ok there were 2 mistakes :P
effect 'rollit' active & effect 'rollit' slider 2 50%
how about now?
ok so i opened mappers and then copied and pasted: effect 'rollit' active into "key", and effect 'rollit' slider 2 50% into "action"...pressed enter, and still nothing man lol im prob doing something wrong
ämm no ....
Just seach the key you want to map this action in the list at mappers.
Then copy and paste the action to action - Just leave KEY as it is after you selected your button.
at action you have to paste the code i gave you that post above ;) - the whole code - not just a part - you have to copy the whole code there ;-)
thank so much man it worked
