Topic: [NEW] VirtualDJ 7.3 - Page: 3
Hi my name is Alex I go under a 1 sound productions and I have a problem with my Mac for some reason I can only get it to play music through the head phone jack from the audio jacks in back of my ergo v. I also can't seem tone able activate any skins that I downloaded.
Hi Alex,
Please create a separate thread in the Mac support forum. This thread is purely for the new software version rather than users individual issues.
Thank you
Keith
Thanks! Can't wait to try it!!
... And of course the best news is my "download centre" has lit up!!! :p
Support staff wrote :
groovindj wrote :
Does it only work on text fields? Doesn't seem to work for the year field at the moment. BPM would be useful too.
For numeric field, you can (since v1.0) write 2010-2012 or 120-130 to search in a range
But if you mean to mix text and numeric (like "guetta 2010"), then yes it's not implemented in v7.3.
It will work in v8, and probably in v7.4
v7.4? So we will get at least one more update before v8...
Christmas again!!!???
gonna put it through the ringer the next couple days on the home dinosaur...
This is a great update I just downloaded it and played with it and loved it. Thanks Atomix for the great work.
Charlie
WOW, my two biggest wishes for VDJ just got answered!
I'm ecstatic! Thank you!
Way to GO VDJ!!! and I just had installed the previous version on my new windows 7 setup on the Old Alien (working great!),now I will have to upgrade again but I wont mind...wink,wink ;-)
Charlie Wilson wrote :
So to increase the bottom end I could try
ParamEqualizerHigh = 6 500 Hz (ie 6.5kHz)
ParamEqualizerMedium = 1 700 Hz (ie 1.7kHz)
ParamEqualizerBass = 190 Hz
Settings I'm happy with are 7500, 1350, 180 but its a personal taste at this point.
whats Output Headroom?
Hi Cyder,
Thanks for chipping in, these settings are personal of course to your equipment.
All I really want to know is by lowering the low frequency number does this increase the bass?
As you know it changes the frequency but it's relative to your particular setup. Best have a play with the numbers to see what is best with your gear eg. If you have subwoofers a lower number is better.
Thanks a lot for the Update. Its really amazing, the sound engine has gotten a noticable boost in performance and quality!
that's really one of the biggest news for me ;)
Can't wait for VDJ8 ! Keep up the good work!
All the best
DJ Acr0
The new sound engine sounds much better ... I will have more time to play with this tomorrow but good work
I think I set w7 updates to auto and it has mess things up.after i downloaded 7.3 I still see 7.2? ...plus it reloaded (updated?) the Hercules RMX drivers and that was screwed up.what should I do? uninstall VDJ 7.2 first? I will lose all the remapping I just did yesterday...
@DjCel
Is there a way to modify the volume of every eq knob to obtain full eq kill on the parametric function?
WOW WOW WOW!!!! Sound is amazing!!! Wasn't really expecting the tremendous difference, so stoked!!!! Played some older mp3s to test it up against newer stuff, holy cow what a difference!!!
Thank you Atomix!!! You guys are really outdoing yourselves once again!!!
nevermind just as soon as that I remembered.reinstall new version and select "standard" install,NOT custom and reLaunch...Got the v. 7.3 ,also had like 20 tabs on firefox opened (?!?!)...clogging things a bit...duh!
Great!!!
The limiter is not good for beatmixing and the parametric eq is not good for eq kills, so I will be keeping those features disabled for now. Other than that a good, so far stable release;^]
15%
