Pls where can i download the drivers for MC CRYPT CONTROL 5 and does it support virtual dj 7prodj 7pro
geposted Mon 12 Nov 12 @ 1:39 pm
It's not on the list of native supported controllers, but it looks like it may be based on a generic model that has been rebranded. From searches on the Internet, it appears to comes with VirtualDJ LE included, so should also be natively supported in the latest VirtualDJ Pro.
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.) Your VirtualDJ LE for Hercules RMX entitles you to a considerable discount off the cost of upgrading.
geposted Tue 13 Nov 12 @ 7:35 am
Hey :) i have a mc crypt MIDI 5 Controller but i lost my serial key? What should i Do? ^-^ please help me :D
geposted Sun 02 Nov 14 @ 12:29 am
If you have lost your LE license key then your only recourse would be to contact the manufacturer to see if they will issue a replacement.
The other option would be to install VirtualDJ v8 to see what the controller is detected as, make sure it works and then purchase a new license to use that controller.
geposted Sun 02 Nov 14 @ 5:02 am
AI have Midi-7 but i lost my seral number how do i get it
geposted Fri 13 Feb 15 @ 12:59 am
Please read the message directly above yours.
geposted Fri 13 Feb 15 @ 5:42 am
