Forum: VirtualDJ Plugins
Topic: Variable saving across sessions
i am working on a mapper that uses a colour grid of pads similar to the APC 40 and i needed a way to save the colour variables across sessions.
at is there currently any plugin or method to do this?
there are 16 pads with 8 colours each so thats 128 boolean values per page, or if it can be done via a binary array, only 2 bytes.
im looking at storing approximately 5 pages worth of colour settings once everything is done, however the ability to have it open ended would be amazing.
heres a video of the setup without the ability to save colours between sessions
https://www.facebook.com/video/video.php?v=514448101908129
geposted Sun 18 Nov 12 @ 1:49 pm
Currently there's no way to save variables thru sessions.
However VDJ automatically saves and restores pannels. You can do what you want with extensive use of pannels and sub-pannels. Just try to keep the names short since there's a limit you must not cross.
