Kai exhgoumai....edw kai merikes meres...kati den mou kathotane kala me ton hxo...toso sto magazi oso kai sto spiti.O hxos san na "eklaige"se kapoia xamhla shmeia twn tragoudiwn (me fwnhtika pianakia...xamhla perasmata genikws)kai ta prima(high) akougontan san "mpoukwmena"...kai kapoies fores akouga kai kati periegous thoryvous(san autous pou kanei ena cd otan den einai katharo)to setup mou(to twrino)Fujitsu Siemens laptop me I5 epexergasth sta 2.5 8gb ram 750gb eswt. sklhro kai grafika intel(den paizw videos)kai Reloop Terminal mix 2 controller..To latency mou sta 8ms kai to pc setarismeno mono gia mousikh(me oles tis gnwstes proteinomenes rythmiseis)...to Dpc latency checker mou dinei times apo 35-96ms .
Sto performances tou vdj(ennoeitai to 7.3 Pro)to latency sto auto,kai sto master tempo sto advanced streching Limiter sta 2db equalizer parametriko kai oi colored waveforms apenergopoihmenes..EDW EIMASTE..!!!!Allazw thn rythmish apo advanced se fast streching kai MAGIC ..!!!O hxos allaxe...poly kathara prima kai egine diafanos(diauges)problem 1 solved loipon estw kai me mia mikrh thysia sthn poiothta tou master tempo kai sto pitch bend me ta jogs(gourgourizoun)alla ok...VDJ 8 is on the way...kai as paizw se xamhloteres diafores bpm..Anyway,sta ypoloipa twra...
Agorazonta sto controller..anakalypsa oti den eixe trofodotiko diko tou kai epeidh o fovos fylaei ta erhma...phga kai agoras ena rythmizomeno trofodotiko symfwna me tis prodiagrafes tou kataskeuasth apo ena hlektronikadiko sth geitonia mou(shmeiwste oti tis 2 3 prwtes mers epaiza mono me trofodosia apo to usb xwris provlhmata....8-9 wres seri)....Shmera to prwi loipon mou erxetai h idea na mhn valw to trofodotiko...AUTO elyse kai ta ypoloipa thematakia...gia na mhn rwthsei o Phantom...h polikothta swsth sto visma kai sta 6v h trofodosia...DEN XERW an me ena pio poiotiko trofodotiko den exw provlhma...alla pros to paron ...Mono usb powered..PROSOXH STA TROFODOTIKA LOIPON..
geposted Mon 10 Dec 12 @ 4:10 am
Πρέπει το τροφοδοτικό να είναι ποιοτικό και "σταθεροποιημένο" για να μην έχεις θορύβους. Διαφορετικά εισάγεις θορύβους από τα κυκλώματα του τροφοδοτικού. Μια γνωστή λύση για να βοηθήσεις την κατάσταση είναι το κόλπο με την γείωση, αλλά και πάλι δεν έχει πάντα καλό αποτέλεσμα.
Πάντως για ένα "καλό" και "ποιοτικό" τροφοδοτικό οι τιμές ξεκινάνε τουλάχιστον από τα 30 ευρώ και ανεβαίνουν!!!
geposted Mon 10 Dec 12 @ 4:34 am
thanks 4 the tips!
geposted Tue 11 Dec 12 @ 6:57 am
