Forum: VirtualDJ Plugins
Topic: SBDJ LogoGrow
I can use this plugin rather nicely on my old Pentium 4 desktop, however, on my new 8 gB laptop,
I cannot, and as soon as I try to activate it, I receive a popup message saying "d3dx9_43.dll is missing". Not sure why my very old machine would have this in there while my brand new lappy doesn't. Why? And where do I obtain it for the lappy, in order to use most of his transistions? Thanx in advance.
geposted Mon 10 Dec 12 @ 7:43 am
Just update DirectX from Microsoft website...
Thats what I was thinking but my new laptop is already the latest direct x10, which my pentium 4 doesn't even have, but still works with the plugin. How is an upgrade to direct x10 going to include a directx 9 file that it should already have?
Just run the DX9 setup from the web. It will do the rest automatically...
Also you may want to install the following:
VC 2005 Redist
VC 2008 Redist
VC 2010 Redist
All these 3 and DX9 will allow you to run almost any plug-in available on this site...
VC 2005 Redist
VC 2008 Redist
VC 2010 Redist
Thx Phantom, but will running dx9 on top of dx 10 change anything in dx10 and mess this up. I thought I read once before that once the newer ones are installed, you can't undo anything when it comes to those updates with directX.
I meant dx11, and was wondering am I actually being asked to downgrade to dx9??
Just use the online installer. It automatically picks up the files that are missing and the files that must be updated. A lot of things have changed the last few years... :P
EDIT: No you won't downgrade. You will just install DX9 specific files that are missing from your system.
How do I find what VC Redistributions I already have??
Control Panel -> Add/Remove Programs
Windows 7 doesnt have add/remove programs, but I did find what I had and got everything working now. I really need help on my other thread above this though. :)
Everything worked out great, thanx.
Just an update, Windows 7 has a "Uninstall a Program" under Programs in the control panel.
