in virtual dj 8, i wish i can edit beatgrid and save (lock) song beatgrid (like in traktor)
geposted Tue 25 Dec 12 @ 4:33 pm
Is this a feature yet?
geposted Thu 15 Oct 15 @ 10:40 am
You can edit/ adjust the beat grid and it is saved, as for locking it, just don't edit it again.
geposted Thu 15 Oct 15 @ 11:11 am
What happens if you accidentaly hit the tap button after you just loaded a track. There is no undo function either...
Being able to lock the beatgrid would be great!
geposted Sun 07 Aug 16 @ 12:27 am
+1
geposted Mon 08 Aug 16 @ 7:43 am
+1 from me.
geposted Tue 16 Aug 16 @ 7:44 pm
+1
geposted Tue 16 Aug 16 @ 11:20 pm
One trick seems to be if you add a variable BPM... So add a variable BPM marker to the end or start of a song to "fix" the grid to a song you spend time setting right.
Some songs are easy to bpm but others like "beatless" instruments or vocals do take time preparing and setting right so it sounds good when mixing with another song or adding a sampler to it.
Using this variable BPM trick I am able to save my "precious" time I spend gridding these songs right so they sound just right when mixing. :-)
A little lock would be a great feature though, just like being able to lock the cue points.
geposted Wed 24 Aug 16 @ 10:00 am
+1 for lock function !
geposted Fri 26 Aug 16 @ 2:04 pm
