Is there a parameter that I can use to make it so that when the currently playing loop reloops a video effect activates. The purpose being to have a second second of loop in loop outs that make it so the the negative video effect activates each time the video reloops? I'm using an akai mpd 26 and am filling my drumbank with loop functions and effects and the like to use with a single time code set up. First question posted. Sorry if this is in the wrong section. Please and thank you.
deosi
deosi
geposted Fri 04 Jan 13 @ 4:14 am
You could probably do it using my cuemacro plugin, which requires Pro Full.
geposted Fri 04 Jan 13 @ 8:13 am
Care to elaborate?
geposted Fri 04 Jan 13 @ 9:38 am
CueMacro is a plugin that allows you to add VDJScript to a cue point and can trigger almost anything. In fact I used it just new years eve to trigger a Clipbank video for a cue point for every chime in the countdown track.
However, like all plugins, skins, etc. you need the full pro version to be able to access the download area to download the plugin.
Cheers,
Roy
Cheers,
Roy
geposted Fri 04 Jan 13 @ 10:14 am
It is one badass plugin!! And VDJ script is stupid powerful!!
geposted Fri 04 Jan 13 @ 11:13 am
