I purchased some sound effects from the same place I get mp3 from.(mp3 app on my phone). Song transfer fine but the sound effects won\'t play on WMP. I get this error below. Thing is they don\'t even show up in VDJ. Some samples I downloaded from here also give me this error. Is it something I have to update on my pc? I have Windows 7. Thanks...
geposted Tue 08 Jan 13 @ 10:38 pm
Where do they come from? What format are they in?
It's possible that they're recorded in something other than 44.1khz 16 bit (CD standard).
If they're 48khz/96khz/192khz or 24 bit, or even 32 bit then that could be the issue.
You'll either need to convert them down or use s/w that can handle that file type.
geposted Wed 09 Jan 13 @ 9:35 am
Hi groovin
I bought from the same place I get my music. Through the amazon mp3 app on android phone. I never had any problems with any songs. As a far as I know they are all mp3 format. One is 233Kbps and the other is 141Kbps. They do play on my phone though.
Either way, I never converted bit rates. Could you give a quick rundown on how to tackle this? Thanks
geposted Wed 09 Jan 13 @ 3:40 pm
