hello everyone,
i have one problem... i use hercules 4-MX skin but i want to add some more options to the menu that popup when i am over the button "1" or "2"... and i push the right clik. Where does the skin takes that popup menu from? For example i want to add the option "loop 4".
than you
printscreen: http://www4.picturepush.com/photo/a/11978232/img/11978232.jpg
than you
geposted Wed 16 Jan 13 @ 5:44 pm
Hi.
You will have to decompress the skin file, edit the corresponding XML file for your screen resolution and recompress the files.
I would suggest you to take a look at skin SDK first: https://virtualdj.com/wiki/Skin%20SDK%20.html
It's also available in Greek if you want: https://virtualdj.com/wiki/SkinDevGR.html
If you need further assistance please let us know!
geposted Thu 17 Jan 13 @ 4:58 am
No, that is irrelevant to the skin itself. The buttons are mapped as djc_button and the rightclick action is djc_button_popup
You can not change the context menu of those buttons.
If you really need to have some other actions using your controller you will have to use normal VDJ Scripts, but you will lose the default operations.
geposted Thu 17 Jan 13 @ 6:01 am
thank you both of you for your help. it seems like now is ok. I changed code in the xml file. Now i have an other question. All of the buttons when i click them directly from pc i also get light to the same button of controller the only button that does not work like that is the Shift button. Here is the code:
<button pannel="djcl2" action="deck left djc_shift off">
<pos x="242" y="371"/>
<size width="30" height="19"/>
<selected x="275" y="1587"/>
<over x="275" y="2150"/>
<down x="275" y="1586"/>
</button>
<button pannel="djcl1" action="deck left djc_shift on">
</button>
<pannel id="djcl1" group="leftside" visible="yes">
<pos x="1" y="1"/>
<size width="1" height="1"/>
<up x="+0" y="+0"/>
</pannel>
<pannel id="djcl2" group="leftside" visible="no">
<pos x="1" y="1"/>
<up x="+0" y="+0"/>
</pannel>
If i push it directly from controller then i get light to pc. Any help?
</button>
</button>
<pos x="1" y="1"/>
<up x="+0" y="+0"/>
</pannel>
<pos x="1" y="1"/>
<up x="+0" y="+0"/>
</pannel>
geposted Fri 18 Jan 13 @ 4:08 pm
Why creating panels ?
Simply have one button with action="deck left djc_shift"
It will act like the button on your controller and will light up the same.
geposted Fri 18 Jan 13 @ 4:20 pm
