do the bits 0x10 and 0x11 act as momentary buttons or do they toggle between 10 and 01 each time the button is pressed?
geposted Wed 06 Feb 13 @ 5:02 am
they toggle:
When A is selected bits 0x10 & 0x11 become 10
When C is selected bits 0x10 & 0x11 become 01
So in essence, while there are 2 bits involved, in practice they behave like 1.
geposted Wed 06 Feb 13 @ 7:06 pm
well, I'm going to have to skip the skin deck change for now...
Whenever I start VirtualDJ, I have to press a button once (any button) on the controller for the buttons to start sending messages (or for VDJ to start recognizing the messages). For example if I load a song on a deck (with the mouse) I have to press PLAY twice before it would start playing. After this initial annoyance all works great.
Is there a special initilization technique I have to use? The controller does send messages even on the 1st. button press, I can see it with the HID Tracer, so it seems Virtual DJ is not interpreting the 1st. button press messages correctly.
I initially thought it could be my HID pages not defined correctly but I am not sure that's the reason since like I said, once I press any button once, all subsequent button presses work as expected even across the different HID pages.
Any suggestions?
Any suggestions?
geposted Thu 07 Feb 13 @ 1:40 pm
Support, what is the <page type="packets"> used for?
Is there a way to have VDJ execute the root HID page and then a conditional HID page using CONSTANT at the same time? On my tests if VDJ enters the root HID page it just never enters the remainig HID pages.
geposted Sat 09 Feb 13 @ 8:43 pm
i myself would like to see some more documentation on other pages.
the wiki/guide page tells us that they exist, but does not tell us anything about what they do or how to use them.
what gives?
its like an icecream van without icecream
what gives?
geposted Sun 10 Feb 13 @ 2:16 pm
Pioneer DDJ-T1 HID Definition is complete!
Well, after countless hours of trial and error, frustration, headaches and after almost 2 months time I have finished my first HID definition/mapper. I definitely picked the wrong controller, even though this is my first attempt to write an HID based definition this controller just seems to be too complex to write out.
Thanks to the Support Staff and TechNZ for helping out throughout the build process. While this could be one of those efforts classified as "loo little, too late", I believe it contributes a good reference value. As detailed documentation on HID implementation is very sketchy at best, observing how this definition was put together could definitely aid others attempting further HID implementaions.
http://www.virtualdj.com/addons/15675/Pioneer_DDJ-T1_Enhanced_Controller_Mapper.html
geposted Wed 13 Feb 13 @ 2:53 pm
Staff, controller mapper awaiting review/approval...
geposted Fri 15 Feb 13 @ 12:28 pm
Unfortunately we do not have the opportunity to test the mapper as we dont have the unit in our Dev Dept. However we have allowed the add-on and we will monitor the thread for any negative feedback.
Download Link
Thank you for sharing.
Download Link
geposted Fri 15 Feb 13 @ 3:57 pm
Could not have asked for more, I'll keep an eye on feedback and address any issues as they are reported. I only wish your DDJ-SX skin was ready, as this controller shares quite a lot of features with the SX units and the skins would have been an excellent complement to this controller mapper set.
geposted Fri 15 Feb 13 @ 5:26 pm
There is a bug with the channel 3 (deck 2 on vdj) and the crossfader. The volume_slider makes video transition when the crossfader_slider is linked in default skin.
I tried to correct the problem but when i got to mappers all i see is a simple , volume_slider for all the channels... so i was unable to fix it...
Any idea ?
Any idea ?
geposted Wed 10 Apr 13 @ 5:46 pm
I'll take a look at it. Not much of a VJ but I'll poke around with the linked crossfader. I'll let you know....
geposted Thu 11 Apr 13 @ 5:07 pm
Are you using a 2-Deck skin?
It seems that just like the DDJ-SX, the T1 wraps decks 1 & 2 into decks 3 & 4 in 2-deck skins. Let me see what Atomix did to fix the issue with the SX but most likely I'll have to rewrite parts of the mapper to address the issue.
For a quick workaround you have 2 choices:
- Use a 4 deck skin
or
- Add nbdecks="4" to the 1st. line of your 2-deck skin's XML. It should look something like this...
<Skin name="VirtualDJ7 (2 Decks)" version="7" width="1600" height="900" nbdecks="4">
- Use a 4 deck skin
or
geposted Thu 18 Apr 13 @ 2:20 am
Ok ... im going to do that and let you know ! thank's !
geposted Thu 18 Apr 13 @ 5:48 pm
I have updated the DDJ-T1 Def/Mapper set to v1.2 and it now works properly with 2-Deck skins.
geposted Fri 19 Apr 13 @ 1:22 am
quisiera saber como puedo obtener este mapeer me urge ayuda nesesito mucha ayuda con esto.
geposted Fri 05 Jul 13 @ 2:38 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
NOTE: You will need to upgrade to the full VirtualDJ Professional at a discount to be able to download and use custom mappers: http://www.virtualdj.com/buy/index.html - DO NOT ask users to send you mappers to which you are not currently entitled or your account will be locked.
geposted Fri 05 Jul 13 @ 4:25 am
how can I get that mapper ddj-t1 for virtual dj
geposted Mon 19 Aug 13 @ 5:31 am
Please do not doubble post your request - you already got an answer: http://www.virtualdj.com/forums/104382/Hardware_Technical_Support/PIONEER_Hardware_Products_%28Setup__Solutions__Fixes__Issues__etc_%29.html
geposted Mon 19 Aug 13 @ 7:46 am
hi i have a ddj-t1 and a ddj-ergo
but i cant download this mapping
please give a link
please give a link
geposted Wed 11 Jun 14 @ 4:05 pm
Mappers are only available to Pro License holders.
You can purchase Pro here: http://www.virtualdj.com/buy/index.html
with this you will also be entitled to download version 8 for FREE.
geposted Wed 11 Jun 14 @ 6:56 pm
