i need to pick some brains....
i'll make a long story short. trying to write a definition file for my midi controller...
ive followed alot of the steps from:
http://www.virtualdj.com/wiki/ControllerDefinition.html
and
http://www.virtualdj.com/wiki/ControllerDefinitionMIDI.html
i've also used the "MIDI devices tool" to get the code:
sysexid="F07E??06020001790300010020120820F7"
vdj sees the controller and my test mapping i've made, so all is good there. here is where i'm having problems....
when i use the tool and press a button (i have 4 rows of 4 buttons)
i get the following when i press then release the button
92 2E 7F 00
82 2E 7F 00
<button note="822E7F00" name="PLAY" channel="2" deck="1" />
<led note="922E7F00" name="LED_PLAY" default="PLAY" channel="2" deck="1" />
I noticed when i reversed the press/release then i was able to get the button to function, although the LED works it flashes like a strobe for 1 second vs just being ON, i'll still have to tinker with that part.
another issue is although im pressing the key i want, its mapping to the button 2 rows down. i think im having a hard understanding of understanding the code of the key presses. also my buttons have LEDs that are on and change to a different color when pressed, not sure if that is an issue or not
if anyone can help me that would be great, thanks
cheers
and
92 2E 7F 00
82 2E 7F 00
cheers
geposted Mon 21 Jan 13 @ 11:11 am
whenever i map with MIDI i use Chackl's controller definer tool to sniff my MIDI.
it provides all the data you need in a much more readable format.
http://www.virtualdj.com/addons/12994/VDJ_MIDI_Controll_Definer.html
geposted Mon 21 Jan 13 @ 1:14 pm
Your definition is incorrect. You just need to specify the MIDI note number for each button/LED (2E in this case), not the full MIDI message!
I.e
<button note="0x2E" name="PLAY" channel="2" deck="1" />
<led note="0x2E" name="LED_PLAY" default="PLAY" channel="2" deck="1" />
(The 0x is important to tell VirtualDJ the number is hexadecimal, not a normal decimal number.)
As far as the above MIDI messages are concerned, they mean the following:
92 2E 7F 00 - '9' is MIDI note on (Button pressed), 2 is the MIDI channel number, 2E is the note number, 7F is the velocity, the 4th byte 00 isn't used by MIDI notes.
82 2E 7F 00 - '8' is MIDI note off (Button released), 2 is the MIDI channel, 2E is the note number, 7F is the velocity (Technically, this should normally be 00 for a button being released.)
I.e
geposted Mon 21 Jan 13 @ 1:25 pm
thanks guys, currently at work, but when i get home i'll adjust my mapping and report back
cheers
cheers
geposted Mon 21 Jan 13 @ 4:55 pm
you should also note that miditrace has a zero index meaning that channel 0 is really channel 1 in the definition file. so for the example above channel 2 is really channel 3 when defining
geposted Mon 21 Jan 13 @ 8:18 pm
for whatever reason it works on channel 2 but not 3, could be the controller and the current settings i have it at
geposted Mon 21 Jan 13 @ 10:41 pm
