Exω το stanton djc4 με την le και 2 mk2. Me την [pro full η συνδεση των mk2 με το midi ειναι απλα plug n play,σωστα?Και κατι ακομα,το πληκτρο tap τι ακριβως κανει?
geposted Fri 15 Feb 13 @ 10:12 am
oxi den einai plug and play, theleis mia karta hxou gia timecodes me 4in/4out.
Me to Tap mporeis na metriseis xeirokinita to bpm enos tragoudiou
geposted Fri 15 Feb 13 @ 11:28 am
Exw tin entypwsi pws i DJC-4 exei tin dynatotita na treksei Timecodes, ara den tha xreiastei alli karta ixou.
geposted Fri 15 Feb 13 @ 11:35 am
Stin pisw pleura yparxei enas diakoptis. Otan autos einai sto PC tote ta LineInputs mporoun na ginoun eisodoi stin karta ixou kai epomenws na doulepsei to Timecode. Ola auta omws einai stin thewria. Den exw ton controller, opote mia dokimi apo pleuras sou tha itan oti kalytero.
Katevase tin Home Free version i opoia ypostirizei Timecodes gia 10 lepta kathe fora pou tin ksekinas pali, kai akolouthise auton ton odigo gia Timecodes.
http://www.virtualdj.com/wiki/TimeCode%20Config.html
geposted Fri 15 Feb 13 @ 11:44 am
Hmm, nai exeis dikio kai malista exei phono preamps gia pikap...
Synithos oi konsoles autis tis katigorias den exoun..
Apo to manual :
Inputs: Line/Phone x 2 (RCA), MIC x 2, Aux x 1, USB type x 2
Outputs: Master x 2, Headphone x 2
3band EQ with Full output kill function for each channel
MP3player/tablet friendly Aux input
MICinput
Headphone with level control and cue mixing
Dual headphone jacks (1/4" and 3.5mm)
Dual 10 LED monitor display
DVS direct mode for timecode DJing software
Touch-sensitive jog wheels
Jog wheels sensor adjust knobs for each wheel
Manual edo :
http://www.google.gr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.stantondj.com%2Fpdf%2Fproducts%2Fcontrollers%2Fdjc4%2FDJC.4%2520Manual.pdf&ei=SoMeUePeDI3Nswbj74DIDQ&usg=AFQjCNFHo96ux5mPdcv5U3ERaWxsg-3WLw&bvm=bv.42553238,d.Yms&cad=rja
geposted Fri 15 Feb 13 @ 12:59 pm
Αλλη μια ερωτηση ενος "ασχετου" η καλυτερα σχετικα νεου στο ψηφιακο djing,μιας κι ειμαι της γενιας των mk2, τι ειναι timecode? Πςς μη γελατε ε. Μηπως ειναι καποιου ειδους κωδικοποιηση που κανει ο controller στα σηματα απο εξωτερικες πηγες για να τα βγαλει στα ηχεια? χμμμ :)
geposted Fri 15 Feb 13 @ 4:22 pm
Timecode Vinyls ή CDs, είναι βινύλια ή CDs που μέσω ενός ψηφιακού κώδικα δίνουν τη δυνατότητα στο χρήστη να χειρίζεται τα μουσικά αρχεία του υπολογιστή του, σαν αυτά να ήταν εγγεγραμμένα σε ένα κανονικό βινύλιο ή CD. Δες και εδώ: http://en.wikipedia.org/wiki/Digital_vinyl_system
geposted Sat 16 Feb 13 @ 5:19 am
χμμ μπορεις να γινεις λιγο πιο επεξηγηματικος? Καποιο βιντεο αν υπηρχε ισως..Γινεται δηλ να δουλεψω τα mk2 ως timecodes? Δεν μου ειναι κατανοητο ολο αυτο
geposted Sat 16 Feb 13 @ 1:44 pm
[quote=jo iaveris]χμμ μπορεις να γινεις λιγο πιο επεξηγηματικος? Καποιο βιντεο αν υπηρχε ισως..Γινεται δηλ να δουλεψω τα mk2 εφοσον ο controller υποστηριζει timecodes? Aν ναι χρειαζεται μηπως και κατι αλλο?
geposted Sat 16 Feb 13 @ 3:49 pm
για να δουλέψεις με timecode χρειάζεσαι 2 βινύλια (ιδικά) με timecode κώδικα μια κάρτα με 2 εισόδους (στέρεο) και 2 εξόδους (στέρεο) και βέβαια το πρόγραμμα που υποστηρίζει DVS (virtualdj pro)
η λειτουργία έχει ως εξής το πρόγραμμα μέσω τις εισόδους της κάρτας διαβάζει το χρονοκώδικα από τα βινύλια και έτσι ελέγχει το ψηφιακό αρχείο σαν να είναι αναλογικό έτσι μπορείς να παίξεις τα mp3 σαν να είναι αναλογικά τραγούδια γραμμένα στο βινύλιο. το ίδιο μπορεί να γίνει και με cd.
geposted Sat 16 Feb 13 @ 4:08 pm
ok με το vdj pro αλλα επιπλεον καρτα ηχου δε νομιζω εφοσον ο controller εχει ενσωματωμενη και υποστηριζει μαλιστα timecodes
geposted Sat 16 Feb 13 @ 4:14 pm
να πω ακόμα πως το timecode δεν είναι τίποτα άλλο πάρα μονάχα ένα αναλογικό σήμα δυο συχνοτήτων που το πρόγραμμα το αποκωδικοποιεί και καταλαβαίνει αν πάσα στιγμή τι θέση στο χρόνο με επακόλουθο να μπορεί να καταλάβει την θέση και την ταχύτητα!!!
geposted Sat 16 Feb 13 @ 4:17 pm
μίλησα γενικά πως δουλεύει το σύστημα προφανώς ο κοντρολερ σου έχει την κατάλληλη κάρτα για να μπορείς να δουλέψεις έτσι
geposted Sat 16 Feb 13 @ 4:19 pm
Aγοραζοντας 2 timecoded vinyls δηλ παιζεις ολα σου τα mp3 απ'το laptop μεσα απ τα timecoded βινυλια,Μαγεια! Τhanks man!
geposted Sat 16 Feb 13 @ 4:33 pm
όλα αυτά στην θεωρία στην πράξη θέλει κάλο στήσιμο του μηχανήματος και σωστό σετάρισμα του προγράμματος
http://www.music123.com/productDetail/productDetail.jsp?entSkuId=700625000000000&CJAID=10541923&CJPID=3445586
http://www.virtualdj.com/forums/169903/Greek_Forum/__931___965___957___964___945___947___942____947___953___945____964___941___955___949___953___959____968___951___966___953___945___954___972__DJing_.html
http://www.virtualdj.com/forums/135430/Greek_Forum/__928___969___962____957___945____961___965___952___956___943___963___949___964___949__timecode_cd_s___956___949____956___943___945__Maya44___.html
geposted Sat 16 Feb 13 @ 4:53 pm
Thanks φιλε
geposted Sat 16 Feb 13 @ 4:59 pm
