OK, so I get an error message with certain song in my database. Kind of a bummer because I cant play those songs. I was told that they were DRM protected from iTunes originally so if I use iTunes+ it should correct the issue. When looking into it I'll need to turn on/subscribe to iTunes match which will store all of my music in the Cloud. Then I should be able to delete the original and redownload it (for free).
Will I have access to the cloud (and therefore all of my music) everywhere I go to work or do I need a wifi hookup?
Any other ways to deal with the original DRM songs?
Thanks
Thanks
geposted Fri 22 Feb 13 @ 8:25 am
If you download the music from the cloud onto your computer then you should be able to use it off-line with no connection.
Alternatively, you could purchase non-DRM versions of the appropriate songs (I.e: Purchase them again from iTunes.) This would be recommended if it's only a few songs that are DRM protected.
geposted Fri 22 Feb 13 @ 11:23 am
