Forum: Old versions
Topic: Virtual Dj With Numark Mix Track Pro 2 - Page: 1
Hey Ladies and Gents
I'm having a issue with getting my Mix Track Pro 2 to work with Vitural DJ Pro (Full) Ive configured it how It was show to do, yet it still doesnt work with my Mixtrack Pro 2, Question im asking how do I get it working and is vitural Dj Work with Mixtrack Pro 2, NOT Mixtrack Pro 1. Many thanks
Z, Bredin
geposted Thu 28 Feb 13 @ 12:33 pm
The Mixtrack Pro 2 is a brand new product, so at this stage there's no mapping supplied with VDJ.
However, if you check the MTP2 product page on the Numark web site, there's a VDJ mapping available to download.
i have the same midi controller numark mix track pro 2 and just i can get mappings for traktor but i need for virtual dj the version i have is virtual dj 7 pro
and i need to record a mix or the mixes i can need for that
some help for this please
i asked in westend dj in the shop i´ve bought and them said i can make running with virtual dj 7 pro
but the question is how can i do this thank you
Read my previous message! The mapping is on the Numark web site.
If you're using VDJ Pro you should register your serial number here, so that you can download updates, mappings, plugins, etc.
Thanks for the note groovindj. We have been looking at purchasing this controller and I wanted to make sure there was mapping available before purchasing.
Thanks!!
Can you download the mappings for the numark mixtrack pro on the virtual dj home software.
VDJ Home doesn't support controllers.
I just purchased the new MixTrack Pro2, and I assumed that VDJ would support the Pro2 because it supports the regular Mixtrack and the first Pro. So I don't understand why VDJ doesn't support Mixtrack Pro2. I feel stupid because I bought it, and I hate Serato, it is so confusing. If VDJ is going to support the Pro2 then why is it taking so long, and when is it going to happen?
Mixtrack pro 2 is supported in VDJ. You just need to have VDJ Pro. You can use your discount from the first mixtrack you already have registered on your account, and upgrade.
As above the Numark Mixtrack Pro II is natively supported with the latest Pro Full version . https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
the LE version of VirtualDJ that came bundled with your old Mixtrack will only work with that unit and no other. You will need to upgrade your LE version at a discount https://virtualdj.com/products/oem.html . Yu can test your controller with VirtualDJ Home Free version https://virtualdj.com/download/free.html prior upgrading. Home Free version will work with your controller for multiple 10min sessions.
I just bought a Numark Mixtrack Pro 2 controller and it came with Serato which I totally dislike. The Virtual DJ Home Free edition that I have will not work with the controller I bought. It says I need the PRO version. will VirtualDJ Pro Basic work or do I need the VirtualDJ Pro FULL?
Hello, I have Numark Mixtrack and I saw that I can download extra effects and I was wondering how I insert them into my software. I am just getting started and was wondering if you guys could help me.
Thanks.
How much is the upgrade from LE to Pro?
It depends on what product you are upgrading from.
You can find out by going to https://virtualdj.com/buy/ and entering your VirtualDJ LE serial number in the box provided.
I am ordering the Mixtrack Quad (retail price~ $399.99) do you think you could tell me the upgrade from le to pro?
I Connot Download A Skin of Numark Mixtrack Pro 2... Can U Pass The Website..Thaks
37%
