Forum: VirtualDJ Plugins
Topic: How to write a MPM column plugin?
Hello
I would like to have a "measure per minute" column, instead of beat per minute. That is just a bpm / 4 value, and should be pretty simple to implement. Does the SDK support this? And how to do it?
I'm a pretty experienced C++ developer, just just a few hints should be enough for me.
Many thanks!
G.
geposted Sun 03 Mar 13 @ 6:13 pm
You can't add columns to the browser, you would have to re-purpose an existing field. Entering data into a field doesn't require the SDK either :)
