I have an annoying problem.
Using macbookpro 10.8.2
vdj 7.3
Everytime I sort my music, I use ratings. As soon as I move the tracks that I have rated to another folder, the file become unscanned & the rating is lost.
Haven't had this problem with windows 8 & vdj 7.3
vdj 7.3
geposted Wed 06 Mar 13 @ 12:08 pm
This is the same error with field1 and field2 camp.
Even when i use the internal virtual dj explorer.
i dont solve this problem yet. ;(
geposted Sun 17 Mar 13 @ 3:15 pm
thougths???
geposted Mon 18 Mar 13 @ 8:25 pm
Haui70 wrote :
Date: Thu 07 Mar 13 @ 3:21 am
Teamer: Haui70
Message: Hi,
this is a known issue on mac side and should be fixed with one of the next version.
This should be done in the next few weeks.
Kind regards
VirtualDJ Support Team
ATOMIX PRODUCTIONS
Teamer: Haui70
Message: Hi,
Kind regards
ATOMIX PRODUCTIONS
this wasn't fixed in 7.4
geposted Thu 21 Mar 13 @ 2:26 am
It is fixed with 7.4!
I can move, copy etc and do not loose anything.
>Deinst. VDJ (backup your database)
>Use the following tool
https://virtualdj.com/addons/15709/VDJ_Plist_Cleaner__mac_osx_.html
>Install only the 7.4 from your download center
Then try it again!
Then try it again!
geposted Thu 21 Mar 13 @ 2:54 am
ok thanks
geposted Thu 21 Mar 13 @ 8:41 am
You're welcome :-)
geposted Thu 21 Mar 13 @ 8:48 am
I take that back....NOT FIXED!
geposted Thu 21 Mar 13 @ 9:12 am
Not FIxed yet ...i tested here right now and Nothings...
geposted Tue 23 Apr 13 @ 9:53 pm
FIXED! in vdj 7.4.1
I can now place cue points, add rating, comments, etc. then move the file to another folder and file info stays.
Good Job
Thanks
Good Job
Thanks
geposted Thu 12 Dec 13 @ 7:20 am
