Forum: Greek Forum
Topic: [UPDATE] VirtualDJ Ver 7.4.1 - Page: 1
apopsisdjPRO InfinitySenior staffMember since 2003
VirtualDJ 7.4 (20 March 2013)
  • new ContentUnlimited Video and Karaoke subscription plans
  • new improved LiveFeedback recommendations
  • Windows 8 multi-touch full compatibility
  • new actions "slip_mode", "slip", "loop_roll"
  • new actions "motorwheel 'speed'" and "motorwheel 'invspeed'" (for Denon motorized wheels)
  • midi definition <jog> can have ccmsb2="" for 21-bit messages
  • device definitions can include firmware update messages
  • fixed <slider orientation="circle"> with negative angles
  • fixed potential crash with malformed id3 tags
  • fixed transition applied to audio-only plugins on Mac
  • fixed potential crash when using clipbank plugin on Mac
  • fixed potential crash when using cover download dialog on Mac
http://www.virtualdj.com/forums/176004/General_Discussion/_NEWS__VirtualDJ_7_4.html
VirtualDJ 7.4.1 (14 November 2013)
fixed potential issue with Windows 8.1 and high-DPI screens
fixed potential crash on startup with MacOS 10.9 Mavericks
fixed iTunes library sometimes not loading properly
updated NetSearch protocol
fixed windows sometimes not showing when monitor smaller than skin resolution
fixed potential crash on Mac when some favorite folders cannot be found on startup
updated the list of out-of-the-box compatible DJ devices (now compatible with 213 devices)
http://www.virtualdj.com/forums/182813/General_Discussion/_NEWS__VirtualDJ_7_4_1.html
geposted Wed 20 Mar 13 @ 4:29 pm
aledjoPRO InfinityMember since 2005
καλοριζικο!
θα μας κανετε και αναλυση με τις αλλαγες?
btw Τερλεγκα δε βρισκω με το search ενω παλιοτερα τον εβρισκε. τι αλλαξε σε αυτη την υπηρεσια?
geposted Wed 20 Mar 13 @ 4:45 pm
aledjo wrote :
καλοριζικο!
Ksekina me : Slip_mode, loop_roll 0.250 while_pressed, loop_roll 0.125 while_pressed ...ktl
ps. Terlengkas pethane..
geposted Wed 20 Mar 13 @ 6:50 pm
LOOOOOOOOOOOVE IT F.....NG YEEEEEEEEEEEEEES....Ki as viazomoun....kapoioi xeroun...one step before the revolution.....ante ligo ypomonh akoma.....kai ta akoma kalytera erxontai
geposted Wed 20 Mar 13 @ 8:19 pm
Peran apo ta Premium Plans pou edw stin Ellada mas afinoun ligo adiaforous, dyo pragmata apo autin tin version mporoume na kratisoume san pio simantika.
- To Slip Mode kai to Loop Roll me ta opoia mporeis na kaneis polla "oraia" pragmata
- Mac bug fixes. Arketa provlimata (an oxi ola) lythikan stin Mac version.
Opws idi tha diavasate, auti einai kai i teleutaia version 7 pou tha deite. H epomeni version tha einai i 8. Min rwtisete vevaia ksana to pote, giati i apantisi einai gnwsti :)
geposted Wed 20 Mar 13 @ 8:38 pm
αυτο με το slip_mode, loop_roll, ποτε δε το καταλαβα.
εβλεπα συνεχως topics που αναζητουσανε αυτη τη λειτουργεια και πολλοι προσπαθουσαν να φτιαξουν κουμπια για το πετυχουν, οπως το εχει το cdj900.
προσπαθησα και τωρα να καταλαβω τη χρησιμοτητα του και παλι δε καταλαβαινω.
υπαρχει κανενα βιντεακι στο youtube που να κανει "ωραια" πραγματα με αυτο για να το δω?
geposted Thu 21 Mar 13 @ 5:49 am
djsadimPRO InfinityMember since 2006
alex bale se 4 koympia ta parakato
sto 1
sto 2
loop_roll 0.25 while_pressed
sto 3
loop_roll 0.5 while_pressed
sto 4
loop_roll 1 while_pressed
kai des pws simeriferonte
geposted Thu 21 Mar 13 @ 9:20 am
sto 1
sto 2
sto 3
sto 4
το ξερω τι κανει αλλα δε ξερω που ειναι χρησιμο....
geposted Thu 21 Mar 13 @ 10:29 am
geposted Thu 21 Mar 13 @ 10:30 am
ναι το εχω δει, αλλα πρακτικα δε το βλεπω.
high-quality songs from Grooveshark? αφου η ποιοτητα ειναι youtube και η αναζητηση πολυ φτωχη!
στο ContentUnlimited folder, οταν ειμαι στο video δε βγαζει κανενα αποτελεσμα....
παντος το καλυτερο θα ηταν να ειναι free για ολους οταν τα διαβαζει απο το youtube και με συνδρομη οταν τα περνει απο υπηρεσιες οπως πχ itunes, beatport κτλ..
πχ 50 euro/ 100 τραγουδια
geposted Thu 21 Mar 13 @ 10:53 am
εμένα πάντως και στην 449 και στη 451 μου βγάζει ....
έχω όμως intrnet και μπαίνει...
geposted Thu 21 Mar 13 @ 10:58 am
Den exeis katalabei sosta.
To youtube onomazetai tora Netsearch, eno o epaggelmatikos katalogos pou perilambanei to grooveshark proerxetai diaforetikes etairies, analogos to periexomeno.
Allo grroveshark, allo youtube. Des ligo kalytera ta links pou sou edosa
geposted Thu 21 Mar 13 @ 12:39 pm
Des mipos se mplokarei kapoi firewall
μεχρι εδω το καταλαβα. ειχα την 449 πριν και δεν εβγαζε. με την 591 βγαζει κανονικα το netsearch απο το youtube.
για υπολοιπα που τα βλεπω?
οταν ψαχνω στο "search audio", τα αποτελεσματα που μου βγαζει ειναι σε φτωχη ποιοτητα σαν το youtube.
btw το netsearch (youtube) θα επρεπε να ειναι δωρεαν για ολους, αφου δε χανουν κατι αυτοι.... το youtube ειναι free για ολους.
αντιθετος θα ηταν ενα πολυ μεγαλο κινητρο για πολλους να αγορασουν το vdj pro για να εχουν αυτη τη λειτουργια
geposted Thu 21 Mar 13 @ 6:22 pm
Sto Audio Search, ektos apo ta tragoudia tou Grooveshark, logika sou vgazei kai ta Youtube files pou omws einai mono to audio kommati tous.
Auta Audio Youtub files prepei logika na exoun diaforetiko icon apo ta alla (mia gkri ydrogeio)
geposted Thu 21 Mar 13 @ 11:05 pm
βγαλανε και LE editon 7.4 για τις wego και ergo.
μπραβο τους!
geposted Sun 24 Mar 13 @ 6:05 am
Αλέξη νομίζω οτι η συμφωνία με την Pioneer είναι για update μέχρι 8 LE.
Για την WeGo τουλάχιστον είμαι σίγουρος. Λογικά θα ισχυεί το ίδιο και για την ERGO
geposted Sun 24 Mar 13 @ 2:21 pm
πολυ μπραβο τους!
ειχα συνηθισει που στις hercules σταματαγανε τα updates (κακως βεβαια)...
geposted Sun 24 Mar 13 @ 6:59 pm
παιδια το virtual dj ειναι συμβατο με τα windows 8 ??
geposted Thu 04 Apr 13 @ 6:07 am
Ναι, κανένα πρόβλημα.
geposted Thu 04 Apr 13 @ 6:20 am
26%
