Upadated to the new VDJ 7.4 and now none of my internet options work and I can not log in. Says Invalid Username/Password. Also underneath the log in button it says no internet connection? Any advice would be great. Thanks in advance.
geposted Wed 20 Mar 13 @ 7:29 pm
For PC:
https://drive.google.com/file/d/0B379w5vt4TjjeG1BQXcyV2JySkk/view?usp=sharing
For Mac:
https://drive.google.com/file/d/171R7CO6pB7n5-zE8Up-H-e2R9FFHswki/view?usp=sharing
geposted Tue 14 Jul 20 @ 4:01 pm[ selected best answer by Rune (DJ-In-Norway) on Tue 14 Jul 20 @ 4:01 pm ]
Thank you.
geposted Wed 20 Mar 13 @ 8:30 pm
I'm having the same issue (no internet connection)
geposted Wed 27 Mar 13 @ 1:43 pm
Me too, I will now uninstall, then reinstall and see what happens.
geposted Sat 30 Mar 13 @ 7:07 am
No, it's still not showing internet connection.
Is there anything else I can do to fix this.
Thanks.
Thanks.
geposted Sat 30 Mar 13 @ 7:31 am
You get a \"No Internet connection\" message on the top, right side of the Browser ?
Make sure you run the latest version 7.4 from your Download Center.. http://www.virtualdj.com/download/updates.html
Disable your Antivirus and check if a Firewall setting is blocking the connection.
geposted Sat 30 Mar 13 @ 7:54 am
Still not working.
I have tried the "repair" option and have also uninstlled and reinstalled, but still not showing an internet connection, even when I am still logged in here.
I have no firewalls up and I am not running an anti virus.
Is there anything else I can try.
Thanks.
Thanks.
geposted Sat 30 Mar 13 @ 8:14 am
I've just purchased the PRO version and have re-installed the software and I too now have No Internet Connection.
All My Antivirus and Firewall settings have been checked and it's all good.!?
geposted Sat 04 May 13 @ 1:53 pm
I have the same problem, No Internet Connection.
geposted Fri 07 Jun 13 @ 4:52 pm
Ok, I guess I've joined the "NO INTERNET CONNECTION" club after holding off on the upgrade to latest version 7.4 and have a gig tonight. Anybody got any suggestions on the fix? Tried everything posted thus far
geposted Sat 22 Jun 13 @ 8:10 am
I am having several problems with vdj pro and with content unlimited.
I also get a no internet connection message when i know I am connected as everything else works. for starters, it takes a long time after I enter my password so get a logged in message. Then soon after, it says I'm not.
Another problem I'm having is that when i try to upload from the cache to a deck, it often takes a long time or freezes.
I have uninstalled and re-installed. it worked ok for about 20 songs then started acting up again.
Another problem i encountered is that I do an audio search for a song, save it to cache and when i load it to a deck, that title shows up but a different song plays!
Thanks for any help you can provide.
geposted Sat 22 Jun 13 @ 3:38 pm
Same problem. How to fix it?
geposted Fri 28 Jun 13 @ 10:10 am
Semi-same issue here.
When I log in, it takes forever to take my credentials and apply them.
Refreshing cache takes HOURS, IF, it goes through at all.
Some, but not all songs dropped on a deck from cache will freeze vdj for 10-15 seconds before loading the song. (in the DJ world, during a live gig, 10-15 seconds is really more like an eternity)
System Resources:
Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i5 @ 2.40GHz 129 °F
Sandy Bridge 32nm Technology
RAM
8.00 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Dell Inc. 0MFNCV (CPU) 137 °F
Graphics
Generic PnP Monitor (1600x900@60Hz)
(Illegal Vendor ID)
Hard Drives
733GB Seagate ST9750420AS (SATA) 101 °F
Optical Drives
HL-DT-ST DVD+-RW GS30N
Audio
Realtek High Definition Audio
Also looking for some feedback.
Thanks
Brew
System Resources:
Operating System
CPU
RAM
Motherboard
Graphics
(Illegal Vendor ID)
Hard Drives
Optical Drives
Audio
Thanks
Brew
geposted Fri 28 Jun 13 @ 12:57 pm
Just purchased and installed FRESH.
Same issue. Can't login. BOO!
Not impressed so far VDJ.
geposted Fri 28 Jun 13 @ 4:15 pm
the issue we had with the COntentUnlimited Service should be fixed by now. Please Logout and Login again.
PilotGav, you visited our Chat Live but you disconnected about 3 times, without answering my question. Please try to login again. Your issue seems different. Could be related to your bad Internet connection.
geposted Fri 28 Jun 13 @ 4:50 pm
If you mean after the HOUR I waited for a chat support operator to come on - yes I probably wasn't there at that point.
My 150 Mbps down / 10 Mbps up internet connection is rock solid.
Where do I go for a refund?
geposted Fri 28 Jun 13 @ 8:55 pm
I purchased VDJ Just now but can not login to the internet. There is a message appearing "We cannot connect to the Virtual Dj Servers. Please Make sure that you are connect to the internet". So I couldn't Licence the software and couldn't use it. Everything is ok on the computer. I have no firewall at all. I have a fast internet connection. Please fix this problem.
geposted Wed 24 Dec 14 @ 1:45 pm
I have virtual dj 8 cannot log in to licence my product keeps saying no inter net connection checked everything help!
geposted Wed 07 Jan 15 @ 12:00 pm
I have the same problem. Any advice?
I got the computer from my brother and I think he broke something, help anyone?
geposted Mon 12 Jan 15 @ 5:18 pm
hola problema "You are now logged in as in VirtualDJ
You can close this window now " no funciona y no conecta queda pagina tildada
geposted Fri 05 Apr 19 @ 1:15 am
