I have always used VDJ on a PC but recently started experimenting with my MacBook Pro. When I search for a song on my hard drive, the songs appear in the search box, but they will not load from the search results. When I double click or drag the song to the deck, I get an error. If I right click the song and find out where it resides under file info and go to the folder and then load the same song directly from the folder, it loads like it should.
I checked my settings but really don't see an obvious solution and just thought I would see if anyone knew the solution.
Thanks.
Thanks.
geposted Wed 17 Apr 13 @ 10:50 am
Are you using iTunes as your playlist manager?
geposted Mon 22 Apr 13 @ 6:14 am
