I've downloaded some great plug-ins which really
expand the possibillities of mix, but as I noticed
that I use around 4 or 5 different plug-ins quite regullary,
I really don't have time to change and re-set one
of the effects durring the mix. What is your opinion?
Regards
Regards
geposted Mon 15 Sep 03 @ 7:06 pm
You are asking for a way to do more than 3 plug ins? maybe this could be done with a skin?
geposted Mon 15 Sep 03 @ 7:42 pm
No it's not possible by now :(
geposted Mon 15 Sep 03 @ 10:17 pm
With more than three effecs I would foresee hardware troubles. I don't know what kind of pc you have, but my P4 1.8G Laptop has a tough job running VDJ. I think that is the reason they added not more than 3 effects. In Atomix they left out the 16 beat loop for the same reason. Now with faster pc's it is possible to use the 16 beat loop.
Ewout
Ewout
geposted Mon 15 Sep 03 @ 10:24 pm
