Forum: Old versions
Topic: Recording stutter
Hi,
I have a WeGo and LE edition.
When i record a mix it sounds fine live but when i listen back to the wave it skips/stutters about every 3 seconds.
I have no other programs runnings my pc is a 6core 3.5ghz 8gb ram so thats not the issue.
VDJ and WeGo are both latest software and firmware.
Ive set the asio driver to 16bit and increased the buffer no change.
Ive even unplugged my DAC so only the WeGo is plugged in rca out to amp and headphones in it. I set VDJ to single output and apply but when i go back to config it chages to headphones??
Im on windows 8 64bit.
Hope someone can help.
Thanks,
Sean
geposted Tue 30 Apr 13 @ 2:45 pm
Hi,
Any luck in solving this?
Same issue here.
Best, jam-Willem.
Optimise your computer. Make sure you don't have lots of unessential things running in the background. Make tweaks to your system so that it will handle real time audio recording.
There are many guides available online (use Google).
