Coming soon.
It will be 2 decks only. Will come with a custom mapper as well.
geposted Wed 01 May 13 @ 5:20 pm
geposted Thu 02 May 13 @ 7:15 am
Available
Pioneer DDJ ErgoSytle v1.0
http://www.virtualdj.com/addons/15917/Pioneer_DDJ_ErgoStyle.html
1600x900 for now.
Special mapper is on the way
1600x900 for now.
geposted Fri 03 May 13 @ 2:35 am
Mapper to use with the skin is now available
Mapper
http://www.virtualdj.com/addons/15918/Pioneer_DDJ_Ergo_Style.html
Mapper
geposted Fri 03 May 13 @ 2:59 am
nice !
geposted Fri 03 May 13 @ 8:10 am
Hi Sir, can you make a skin resolution 1366x768? tnx
geposted Tue 09 Jul 13 @ 7:44 pm
djdad says: 1600x900 for now.
just wait until the creator sizing in resolutions missing, patience ..!
P.D i will wait in 1366x768 too. thanks dad.
regards
geposted Mon 12 Aug 13 @ 5:02 pm
Both 1600x900 & 1366x768 have the same ratio 16:9. Use the Skin Resizer Tool ;)
geposted Mon 12 Aug 13 @ 8:58 pm
Hi,
Seems that this skin has two major errors...
1st, the "Vinyl" button, doesn't work in both decks..
2nd, it doesn't support 4 decks...
Can you check for the first error?
Best regards.
Best regards.
geposted Thu 15 Aug 13 @ 11:31 am
The Ergo has some kind of hardware vinyl buttons. This means that you need to enable/disable the vinyl mode from the controller and not from the skin. The vinyl button on the skin will follow the hardware buttons of the controller and will show you on the screen the mode that the jogwheels have.
The skin offers just 2 decks. So its not a bug ..lol Its just what the skin offers. Not everybody uses Ergo with 4 decks, and really cant think of a nice way to mix 4 decks with a controller that only offers a 2 channel mixer ;)
Pioneer can say whatever they need for marketing purposes. I say Ergo is 2 deck controller, not 4 !
geposted Thu 15 Aug 13 @ 2:43 pm
Hi,
thankyou for quick response.
Concearning the 2 or 4 deck issue, what i was meant was, that would be nicer if, the skin had a 4 deck support, all it was needed was, change the deck, everytime a user press C ou D buttom.. nothing more.. :)
About the "vinyl" issue, that, for sure, is really a problem, because, in my case, everytime i press the "vinyl" buttom in my controller, the light switches on and off, however, it doesn't really has any effect.
O realised that the vinyl stays always on or off, depending on the state indicated in the skin... and not in the controller.
Please advise.
Thanks.
Please advise.
Thanks.
geposted Sat 17 Aug 13 @ 2:12 am
Como eu fasso pra mim ser um licença? pra mim fazer download..
geposted Wed 28 Aug 13 @ 9:27 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
NOTE: Skins are only available to registered licensed users who have purchased VirtualDJ.
geposted Wed 28 Aug 13 @ 9:32 am
slip mode only works in the skin not when i push buttons(sampler/hot cue)?
Cause mine not swhitching modes by FX buttons
geposted Sun 08 Dec 13 @ 11:25 am
Deleted old mapping an now working! Huge thanx!
geposted Sun 08 Dec 13 @ 11:39 am
Hi
I just bought a used DDJ Ergo V which didnt come with any CDs or whatsoever :/
how can I get Virtual DJ LE and the access to those great skins?
Thanks and best regards,
Matjaz
Matjaz
geposted Sat 14 Dec 13 @ 7:08 am
Please see http://www.virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
For further assistance, please contact support: http://www.virtualdj.com/contact/index.html
NOTE: VirtualDJ LE is limited software and doesn't support using custom skins except during the 20 day trial of the full VirtualDJ. You will need to upgrade from LE to the full VirtualDJ Pro at a discount to be able to use custom skins, effects and much, much more.
geposted Sat 14 Dec 13 @ 11:53 am
Hi,
Regarding this skin, will you consider developing a skin for the new version 8??
Best regards.
Best regards.
geposted Tue 20 May 14 @ 5:59 pm
@ DJDAD: The Pioneer DDJ-ERGO V is defently a 4 deck controller! Because you have 4 deck buttons on the controller. I think the skin must be able to work with all options. It's very lame of virtual DJ to give a skin that not work properly! It's sertenly not 99€ worth.
geposted Thu 28 Aug 14 @ 5:17 am
You do not have to use this skin (when you have a license). You can use any other skin that has four decks.
geposted Thu 28 Aug 14 @ 5:30 am
