yiannis64 wrote :
Mpampi mou , xaxaxaxa , tha garizo.......xaxaxaxa
Den akougetai i foni mou sta akoustika se kamia thesi i entasi.
Sta ixeia akougetai.
Kai episis eno oloi oi diakoptes ston skin , doulevoun , to master volume , kai to mic volume den doulevoun sto skin.
Stin konsola doulevoun kanonika.
Telos mipos na metonomastei o titlos tou topik se reloop beat mix , mpas kai tin exei kai kanena paidi kai voithisei?
Eyxaristo.
djdad wrote :
To MIC tha to akous sta akoustika an gyriseis to Headphone_mix (Cue-Mix) stin thesi Mix (Master). An einai gyrismeno stin thesi Cue, fysika den tha akous tin fwni sou, ektos ki an fwnazeis dynata :P
Eyxaristo.
geposted Sun 12 May 13 @ 1:33 pm
AYTO TO MINIMA MOU ISXYEI
Eyxaristo.
Eyxaristo.
geposted Sun 12 May 13 @ 1:34 pm
Eyxaristo.
Eyxaristo.
Done!!!
geposted Sun 12 May 13 @ 4:24 pm
Lopoin telika den akougetai me tipota sta akoustika to mikrofono , se opoia thesi kai na einai to diakoptaki tou microfonou , kai fysika ta akoustika sto master.
Sta ixeia antithetos , akougetai kanonika to mikrofono , se opoia thesi kai na einai to diakoptaki tou microfonou.
Se tilefono mou sto d.j.mania , mou eipan oti etsi leitourgei , kai oti tha steiloun kai mail stin reloop gia epivevaiosi , kai tha mou apantisoun ,
alla epimenoun oti etsi leitourgei.
Diladi den akougetai to microfono sta akoustika se kamia apo tis thesei pou dinei to diakoptaki tou. (SW-THRU-OFF).
Kai eroto ego pos einai dynaton , na akougontai kanonika kai ta 2 plato , apo to master ton akoustikon , kai na min akougetai to mikrofono , eno akougetai sta ixeia.
Exo katevasei tous teleytaious driver kanonika kai oi rythmiseis mou einai oi eksis:
geposted Mon 13 May 13 @ 5:58 am
Γιάννη δοκίμασε λίγο την εξής εντολή σε ένα κουμπί (στο πληκτρολόγιο)
mic & mic_volume 100%
Επίσης εάν δεν δουλέψει δοκίμασε και το εξής:
deck 1 linein 'mic' on
(Θεωρώ αυτονόητο οτι ο διακόπτης του μικροφώνου θα είναι στη θέση SW)
geposted Mon 13 May 13 @ 6:44 am
Giorgo mou voitha me ligo pos kai ti , giati exo kollisei......
geposted Mon 13 May 13 @ 10:12 am
1) Ανοίγεις τις ρυθμίσεις
2) Πατάς την καρτέλα mappers
3) Απο το drop down μενού επιλέγεις το πληκτρολόγιο
4) Πατάς τον πράσινο σταυρό
5) Πατάς ένα πλήκτρο ή ένα συνδιασμό (π.χ ctrl-alt-f11) και μετά γράφεις τον κώδικα που σου έδωσα
6) Κλείνεις τις ρυθμίσεις
7) Πατάς μία φορά ctrl-alt-f11 και δοκιμάζεις να δεις αν το πρόβλημα διορθώθηκε
8) Δοκιμάζεις ξανά με τον άλλο κώδικα αν ο πρώτος δεν δουλέψει.
geposted Mon 13 May 13 @ 10:47 am
Sto Setup tis kartas ixou exeis Master ta Outputs 3,4 kai Headphones ta 1,2. Dokimase na ta valeis anapoda. Kai anestrepse kai ta Master/Headphones sto SOund Setup tou VirtualDJ episis.
An eksakolouthei to provlima dokimase to eksis...
Apo to Outputs sto Sound Setup tou VirtualDJ, epelskse to Advanced Sound Setup kai dimiourgise 3 grammes.
Master ....Reloop ASIO..Outputs 1,2
Headphones ..Reloop ASIO ...Outputs 3,4
Microphone... Reloop ASIO ..Inputs 1,2
Episis mia alli lysi einai na xrisimopoiiseis ena 4 decks skin kai me to parapanw Sound Setup, epelekse px to Deck 3 i to Deck4 kai to koumpaki AUX (yprxei sto Default 4 Decks skin). Des an pernaei to Mikrofwno sto Deck pou dialekses. An oxi sto parapanw Sound Setup, allakse to Mikcrofono me LineIn
geposted Mon 13 May 13 @ 11:17 am
Orisa sta jog modes to koumpi scratch se aux antistoixa gia to kathe kanali ki etsi den xrisimopoio pontiki katholou gia na patao aux.
Ola kala mexri edo , bebaia den iksera oti eprepe na allakso skin kai na valo to defaut skin 2 deck , kai psaxnomoun me to skin tis beat mix.
Episis , pano sti mixi den ginetai na miliso ap'oti katalavaino me ayton ton tropo , an thelo na akouo kai akoustika sygxronos.
Ostoso sto defaut 4 deck skin , den vlepo kapoio koumpaki aux se kanena deck , outos oste na epilekso to aux tou 3 H 4 deck ki etsi na akouo tin foni mou sta akoustika kai stin mixi.
Kai mporo genika na rythmiso kai mpasa prima kai sto mic etsi.
Alla eipa den brisko koumpi aux sto defaut 4 deck skin.
Kai ama vro koumpi aux , ante meta na do pos tha rytmiso pali to 3 H 4 deck , sto koumpi scratch ton jog modes gia aux.
Thimamai nomizete pos to ekana sto 1 & 2 deck....xaxaxaxaxa
Telos peite moy pou na rythmiso stin reloop asio to buffer length , gia na min exo kopsimata ston ixo?
Htan sto 6ms , kai to exo valei sto 17 ms.
Paidia , xilia eyxaristo!!!!
geposted Fri 17 May 13 @ 7:24 am
Sto Default 4Decks skin yparxoun koumpakia AUX se kathe deck. Einai sta panels EFFECTS.
Ta 17ms sto latency einai polla. Tha patas PLAY simera kai tha paizei aurio.. (tropos tou legein). Mia asfalis timi einai konta sta 8-12ms.
To Default 4 Decks skin exei PFL kai oxi SELECT gia tin proakoustiki. Auto simainei oti mporeis na akouseis perissotera apo ena decks sta akoustika. An peraseis to MIC se kapoio deck (px to Deck 3), tote an exeis patimeno PFL sto deck 3, tha mporeis kai na akous to MIC sta akoustika.
geposted Fri 17 May 13 @ 12:11 pm
Mpampi mou den to exo dokimasei akoma , alla tha to dokimaso kai tha epaneltho drimyteros....!!!!
geposted Tue 21 May 13 @ 10:32 am
Kai eno ola doulevan roloi , ksafnika exthes , tin ora tis ekpompis , eno patao to aux , na miliso apo to ena deck , sto mic , akouo sta akoustika 2 fores tin foni mou , kai den mporousa na miliso , ki etsi stamatisa na patao aux , kai milousa xamilonontas to fader , kanonika xoris na patao aux , kai akouga apo ta ixeia (xamilomena fysika) , gia na mporo na miliso.
Kai san na min eftane ayto , ksafnika se ena tragoudi , to deksi deck , den ksekinage me tipota.
Meta apo polles prospatheies , kai me allagi tou kommatiou , ksekinise...oufff
To kommati en to metaksi pou den ksekinouse , einai katharo , genika den exei kanena cue , k.l.p.
Eleos , ti ithela kai empleksa , ego me ayta ta plastika konsolakia.....tespa tora pou mpika ston xoro tha xorepso.
Ase pou genika , exo thema........kai me tin kanoniko set mou , (kamia sxesi me to laptop) ......alla tha anoikso allo topic gi'auto.
geposted Fri 24 May 13 @ 5:03 am
Opos anafero kai sto proigoumeno post.
Provlima.
Kapoies fores , to ena plato kollaei.
Den ksekinaei me tipota.
Play , play , vre kalo mou , vre xryso mou , tipota!!
Tin proti fora pou mou to ekane ksekolise sto tsak prin teleiosei to tragoudi , apo mono tou.
Tin deyteri den ksekolage me tipota , kai anagkastika , kai ekana search to kommati me ta jog wheels , kai to proxorisa , kai meta ksekinise.
Den thimamai an mou to ekane sto idio deck , (mallon oxi).
Oi drivers pou exo einai oi teleytaioi , kai to kanei meta apo kapoia ora , oxi amesos.
Provlima.
geposted Mon 10 Jun 13 @ 4:43 pm
Gianni, yparxei periptwsi ta jogwheels na exoun rythmistei se ypervoliki euaisthisia. Ta jogs tis Rellop einai touch sensitive. An loipon i euaisthisia einai poly megali, ena kounoupi i akoma kai enas kokos ammou (xaxa ypervallw) einai arketa gia na kanoun to deck na min ksekinaei, afou einai san na kratas to platw me to xeri.
Des sto manual tis Rellop, pws allazei auti i euaisthisia (isws exei kapoio diakopti i kapoio synduasmo pliktrwn) . Valti se xamilotera epipeda.
geposted Mon 10 Jun 13 @ 8:43 pm
Oi rythmiseis tis eyaisthisias , einai apo tin piso meria tis reloop , dyo mikra mayra stogylla koumpakia.
Fantasou tora oti ego (an to ypologisoume san roloi) , oti ta exo sto paratetarto.
Opote poso pio xamila pia.....
geposted Tue 11 Jun 13 @ 5:12 am
Gianni, ta koumpia euesthisias sta jogs me apla logia rythmizoun an tha perasei reuma apo to xeri sou kai tha kleisei kykloma...opos ena dokimastiko katsabidi. Ousiastika den rythmizeis kati, einai on / off : douleuei / den douleuei.
Ego ta exo sto terma deksia.
(Ps. @Mpampi, enas kokkos amou h ena kounoupi.. den mporei na "kleisei kykloma" (den enai diakoptis pou energopoihte me piesi alla touch) ektos an to deutero exei poly makria podia....)
Oso gia to problima pou les nomizo to exo dei kai pisteuo pos exei na kanei me to 'mode' tou jogweel to opoio kathorizetai kai apo to hardware alla kai po ton mapper. Gia auto to ksekolises tin deuteri fora gyrnontas ta jogs.
Xoris na to exo psaksei poly mia pithani lysi einai na oriseis apo tin arxi otan ksekinas to programma ti kanei to jog, epilegontas vinyl i search kai meta na min to peirazeis, an den exei tipota apo ta dyo modes energopoihmeno isos symbainei auto pou les.
Tha to psakso me tin proti eukairia pros to paron dokimase na akolouthiseis ti symbouli mou kai des ana exei apotelesma.
Ego to bazo se vinyl mode sto ksekinima kai gia search etsi kai allios panta orizo 2 buttons. Etsi to jog den allazei symperifora.
geposted Tue 11 Jun 13 @ 6:14 am
