Hi there, I recently made the switch from windows to Mac, and failed to realize that the Kjaerhus plugs were not available on Mac. I use the classic compressor quite heavily in my sets, and would greatly appreciate finding a compatible alternative.
I hope someone can help me out here, I can't even get a clear answer as to whether VSTs and AUs are compatible with the mac version atm.
geposted Thu 09 May 13 @ 4:12 pm
I don't think they are, although I must admit I haven't tested them
geposted Fri 10 May 13 @ 6:11 am
Sounds Like I should look at getting paralells then... :p
geposted Mon 13 May 13 @ 1:38 pm
Running a demanding application such as VirtualDJ in a virtual PC environment such as Parallels may not give you very good performance, especially if you are doing more than just basic audio mixing.
A better option is to use BootCamp to natively run Windows on your Mac (In addition to MacOS.) This will give you the best of both worlds and optimum performance.
geposted Tue 14 May 13 @ 4:46 am
