I've searched the forums and can't find any answers to my problem.
I use around 8 clipbanks (copied and renamed). In the later versions of VDJ (can't remember from which version it changed), my clipbanks save the same 12 thumbnail pictures. They used to have the correct thumbnails for each bank but not anymore and it means I have to try and remember what each bank contains. The blue border shows in each bank which slot is selected but only one set of bitmap thumbnails. The bitmap files were copied and renamed the same as the bank so that's not the answer.
Anybody shed some light on this?
Oops! Macbook Pro i7 bootcamped with Windows 7 using the latest VDJ 7.4
geposted Sat 11 May 13 @ 4:58 am
Nobody?
geposted Fri 17 May 13 @ 2:41 pm
Still no answers to this problem.
As there is no more updates to version 7, hopefully this will be fixed in V8, we shall see.......
geposted Tue 30 Jul 13 @ 1:46 am
I use to have BLANK/BLACK for thumbnails too. I converted my clipbanks to MP4 (also removed the audio in the process).
No more problems since then.
I think if the file is also VOB, no problem. But MPG gave me the problems.
geposted Tue 30 Jul 13 @ 11:40 am
