Hello to all guys i need a hand with the old boxes that I found in the attic are quite big and I want to use are sansui s-m800 (image link: http://i1301.photobucket.com/albums/ag105/canapippo/975616_451392494953910_1639626776_n_zps1facc401.jpg)
I have been assured that work but instead of a classic attack jack or another year of copper wires and it seems I do not know how to use what I can do to you? there is an adapter or anything else I can try? I would at least try them out with the TV or computer
(image link: http://i1301.photobucket.com/albums/ag105/canapippo/975190_451392498287243_866781921_n_zps4392453f.jpg)
look for your answer thanks
I uploaded the photos to help you better understand my problem I hope can be useful
geposted Mon 13 May 13 @ 12:10 pm
          If you are asking about connecting the wires from an amplifier to the speakers, then it's very simple.
The connectors on the rear of the speaker are spring loaded. When you push on the red or black buttons, it will reveal a small hole.
Insert the bare end of the cable into the hole.
IMPORTANT! Make sure that you keep the polarity the same. Negative (-) on the amplifier must connect to negative (-) on the speaker, and positive (+) to positive (+). Both left and right speakers must be - to - and + to +.
Identify the wires. One of the pair should be slightly different to the other, in colour or in shape (it may have a raised stripe), so that you can determine which is + and which is -.
geposted Tue 14 May 13 @ 1:14 pm
