Can any one tell me step by step how to rip a promomonly video using handbrake.
I can rip one video at a time . Is there any way of setting it up so it can rip the whole disc into seperate mp4s?
I tried putting chapters in que when i try putting second chapter in hanbrake asks me if i want to overwrite the chapter that is in there.
Help!
Help!
geposted Tue 21 May 13 @ 9:28 am
I've used AppGeeker in the past to convert DVD files. It can handle DVD ripping well on my windows 7.
http://www.ilikemall.com/convert/rip-dvd-to-mov-mac.html
It supports in-batch process, and easy to use.
If you to rip DVD movies to common format this is the way to go.
give it a try!
give it a try!
geposted Wed 19 Jun 13 @ 7:00 am
One of the best investments I made for my VJ work (besides VDJ of course!) was buying the Leawo DVD Ripper program. I had been using free ones like Handbrake before but the paid option really does make the process much easier.
geposted Fri 09 Aug 13 @ 10:10 am
Ouvert, choisissez un titre pour déchirer, sélectionnez les formats de sortie et cliquez sur "Démarrer"
En fait, le frein à main ne peut pas déchirer un DVD protégé et il existe peu de formats de sortie pour la sélection. Vous pouvez donc essayer ce logiciel dans le lien: http://www.videoconverterfactory.com/tips/handbrake-copy-protection.html
Il fournit plus de formats et peut copier une grande partie de la protection avancée contre les copies.
geposted Mon 17 Jul 17 @ 9:07 am
