Forum: Italian Forum
Topic: Pioneer XDJ-R1 (Topic Generale) - Page: 1
geposted Thu 30 May 13 @ 3:53 am
Me gusta!!!! ;-)
geposted Thu 30 May 13 @ 4:02 am
pochitodjPRO InfinityModeratorMember since 2007
bell gioiello
geposted Thu 30 May 13 @ 7:51 am
Riporto quanto già scritto su DiJ.it:
La pagina ufficiale del prodotto: http://pioneerdj.com/italian/smp/products/djsystem/xdj-r1.html
Features:
Control the XDJ-R1 wirelessly using an iPhone®, iPad®, or iPod touch® with Pioneer’s all-new “remotebox” app, available free of charge on the App Store™
Wireless Direct allows reliable wireless connectivity with an iOS device, even when Wi-Fi™ isn't available
Auto Beat Loop function automatically loops music at a specified tempo
Features include Beat Sync, Hot Cue, Sampler, Beat FX, and Sound Color FX
Virtual DJ Limited Edition software included with every system. (see download information link below)
All-in-one DJ system with dual CD players and USB port
1 Professional DJ System with Mobility
By utilizing the “remotebox” app1 (available free of charge on the App Storesm) with an iOS device such as iPhone® or iPad®, the XDJ-R1 can be remotely controlled wirelessly, giving DJs the ability to continue their music mixing performance even when they move away from the system. Many of the system’s functions can be accessed directly on the display of a compatible smart device including controlling volume levels, choosing and changing songs as well as the ability to mix songs from a USB device plugged into the system. Users can also apply the “Auto Beat Loop” function2 that auto- matically loops music at a specified tempo as well as intuitively control various effects using the X-Y pads from a smart device.
2 Media Support Including Dual CD Players
Unlike conventional systems, the XDJ-R1 is equipped with dual CD players in addition to a USB port for media playback. The system supports a variety of different music formats including conventional compact discs and MP3, AAC, WAV and AIFF files stored on CD-R/RW and USB storage devices. For added convenience, the unit also offers MIDI support for operation of various DJ software.
3 Free Virtual DJ Limited Edition
The Virtual DJ Limited Edition DJ software3 by Atomix Inc. is included with the purchase of an XDJ-R1. The software features an easy-to-use user interface for the XDJ-R1 and enables optimum enjoyment of various DJ play styles with features includ- ing loops, effects, a sampler and 4-channel mixing.
4 Mix and Match Features
The XDJ-R1 offers a multitude of fun and convenient features for creating unique mixes including:
• Beat Sync4 – With a touch of the Sync button, the system automatically synchronizes the beats of songs analyzed through Pioneer’s rekordbox music management software
• Hot Cue – The system features three points of Hot Cues to enable playback of music from specified points
• Sampler – For added effects, the system’s Sampler function enables recorded sampling sounds to
be added with the press of a button. Sound sources can be recorded from songs on a USB storage device or a compact disc
• Beat FX – Four different effects including Trans, Flanger, Echo and Roll are available to combine with songs currently playing
• Sound Color FX – The system offers four additional effects (Filter, Crush, Noise and Jet) for more creative mixing options
• Quantize Function – Automatically corrects synchronization of effects when using Auto Beat Loop or Beat Effect.
5 Additional Features
• Noise Reduction – To significantly reduce noise, internal analog and digital circuits were separated, and the distance for digital conversion of analog input signals was shortened. All signal processing is conducted using a high-performance CPU for clear audio output.
• Independent 3-band Isolator
• Internal sound card (Audio Interface)
• Complete with Master Out (XLR), Booth Out, AUX and MIC ports
• Optional carrying case (DJC-SC3) available (sold separately)
Specifications:
Input Terminals:PHONO/LINE×2(RCA), MIC×1(1/4inch PHONE), AUX×1 (RCA)
Output Terminals: MASTER OUT×2 (XLR×1, RCA×1), HEADPHONE MONITOR OUT×2 (front 1/4inchPHONE, MiniPin) BOOTH OUT×1 (RCA)
Playable Media: USB storage devices, music CD, CD-R/RW
Playable File Formats: MP3, AAC, WAV, AIFF (only MP3, WAV and AIFF can be played from CD)
USB Storage Formats Supported: FAT32, FAT16
No. of Channels: 2
Wireless Communications Format: IEEE 802.11b/g (2.4 GHz band)
Sampling Rate: 44.1 kHz
A/D, D/A Converter: 24 bit
Frequency Response: 20 Hz~20 kHz
S/N Ratio: 91 dB or above
Total Harmonic Distortion: Max. 0.007 %
Head Room: 19 dB
USB ports: A port×1, B port×1
Maximum Dimensions (W x D x H in inches): 24.5 x 12.1 x 4.2
Unit Weight: 15.0 lbs
RECORDBOX REQUIREMENTS
Supported OS: Mac OS®X (10.5.8 or above), Windows®8/Windows®8 Pro, Windows®7 Home Premium/Professional/Ultimate, Windows Vista® Home Basic/Home Premium/Ultimate/Business (SP2 or above), Windows® XP Home Edition/Professional (SP3 or above), (*Windows® XP Professional x64 edition is not supported)
REMOTEBOX REQUIREMENTS
“remotebox” Mobile Application iPhone® 3GS or above/iPod touch® 3rd generation or above/iPad® iOS5 or above
geposted Thu 30 May 13 @ 8:56 am
Non so chi sia il progettista della scocca,ma non mi pare molto futuristica!
Sembrano due CDJ ed un mixer incastonati dentro un vecchio Nintendo 8bit a cassettoni! ;-)
geposted Thu 30 May 13 @ 4:35 pm
masgagPRO InfinityMember since 2006
me gusta proprio fornita con vdj sara' il top e simile all'aero, come scocca non sara' futuristica ma penso proprio di comprarla !!!
geposted Fri 31 May 13 @ 1:02 am
e poi il nostro grande team e il nostro grande MORAMAX la mappera' sicuramente alla grande !!!
geposted Fri 31 May 13 @ 1:07 am
HACKIDPRO InfinityMember since 2008
Allora non sono il solo a credere che abbia un layout "retrò" per quel prezzo (se sara' confermato intorno ai mille) :)))
geposted Fri 31 May 13 @ 3:24 am
Notizie dal sito UFFICIALE: http://www.pioneer.eu/it/newsroom/news/XDJ-R1/page.html
Pioneer presenta il sistema DJ XDJ-R1 “all in one”: l’unità DJ portatile, predisposta per rekordbox™ che offre controlli wireless da iPhone, iPad e iPod touch
Il sistema DJ completo XDJ-R1 di Pioneer è l’eccellenza dell’integrazione: riunisce deck CD/USB, controlli per DJ software, mixer di prim’ordine, potenti funzionalità performance e – esclusiva assoluta – controllo remoto intuitivo tramite iPad, iPhone e iPod touch.
Pacchetto ideale per i DJ alla ricerca della massima flessibilità senza scocciature, il sistema integrato XDJ-R1 permette la commutazione istantanea fra sorgenti diverse: lettori twin CD, USB e MIDI. I DJ potranno analizzare le tracce mediante il software DJ rekordbox™ integrato e caricare contenuti via USB per accedere a un ampio ventaglio di entusiasmanti funzioni, fra cui l’opzione Beat Sync e gli effetti Beat quantizzati. Altrimenti, potranno attivare la modalità MIDI, per controllare qualsiasi software DJ, come il VirtualDJ LE integrato.
I comandi tattili dell’XDJ-R1 offrono un’illimitata libertà creativa durante le performance live, grazie alle due manopole jog wheel touch-sensitive per lo scratching di precisione, al mixer due canali e ai pulsanti dedicati per loop, hot cue, campionamenti ed effetti di colorazione sonora di qualità professionale.
Progettato per ridefinire la versatilità, l’XDJ-R1 può essere controllato in modalità wireless da iPad, iPhone o iPod touch, utilizzando l’applicazione remotebox di Pioneer. I DJ potranno collegarsi alla rete LAN wireless dell’XDJ-R1 e usare il touch screen del dispositivo portatile per ricercare intuitivamente musica, mixare ed effettuare il mash-up delle tracce, tutto dall’esterno della cabina. L’app offre anche la funzione XY pad: uno strumento bidimensionale per assegnare e manipolare gli effetti Beat e Colour utilizzando un unico controllo intuitivo.
Il sistema XDJ-R1 racchiude tutte le straordinarie funzionalità Pioneer DJ in una sola unità rekordbox ready, portatile e dal prezzo accessibile. I DJ dovranno aggiungere soltanto la loro creatività.
Il sistema DJ XDJ-R1 all-in-one sarà disponibile da giugno al prezzo di vendita consigliato di 999 euro, IVA inclusa.
Informazioni di download
remotebox sarà scaricabile da App Store
VirtualDJ LE sarà disponibile dalla metà di giugno 2013 all’indirizzo: pioneerdj.com/support
PRINCIPALI CARATTERISTICHE TECNICHE DELL’XDJ-R1
Il sistema rekordbox all-in-one racchiude in un unico deck tutto quello che occorre ai DJ
Il sistema XDJ-R1 è DJ-ready e pronto all’uso, quindi non occorre aggiungere altri dispositivi, o districarsi fra grovigli di cavi. Il deck integrato offre riproduzione USB, due vassoi CD, due jog wheel touch-sensitive, un mixer a due canali – più effetti e funzionalità performance mutuate dalle configurazioni Pioneer DJ divenute ormai standard di riferimento per l’intera industria.
Mix da sorgenti multiple, fra cui rekordbox USB, CD e VirtualDJ LE
I DJ possono caricare le tracce con estrema praticità da supporti USB o CD per riprodurre un’ampia gamma di file, compresi AAC (solo USB), MP3, WAV, AIFF e file a 24 bit. Come nella gamma pro-DJ, le tracce preparate in rekordbox possono essere esportate su dispositivo USB, per consentire ai DJ di avvalersi di funzioni come il database delle tracce, le beat grid e gli Hot Cue. Inoltre è possibile attivare molto semplicemente la modalità MIDI per gestire altri software DJ da laptop, tramite connessione cablata, ed effettuare il download gratuito di VirtualDJ LE con il suo mixing video e a quattro canali.
Ricco di funzioni performance della gamma pro-DJ Pioneer
I controlli intuitivi dell’XDJ-R1 rendono ancora più pratica l’esecuzione dei live edit, per performance strabilianti:
rekordbox Beat Sync: sincronizza automaticamente le tracce al master deck, utilizzando le informazioni della beat grid di rekordbox
Auto Beat Loop: effettua automaticamente il loop delle tracce a specifiche lunghezze di battuta
Hot Cue: è possibile accedere istantaneamente fino a un massimo di tre punti Hot Cue su ciascun deck
Effetti Sound Colour: NOISE, PITCH, CRUSH e FILTER sono ripresi dai mixer pro-DJ Pioneer e offrono un filtro passa-alto e passa-basso su ciascun canale, per una manipolazione ancora più flessibile
Effetti Beat: pulsanti dedicati su ciascun deck per gli effetti beat TRANS, FLANGER, ECHO e ROLL con Tap Tempo
Campionatore di quattro battute: accesso a tre campionamenti pre-caricati
Modalità Shift: accesso rapido a funzioni avanzate, fra cui:
Quantize: : aggancia la temporizzazione della battuta degli effetti alle beat grid di rekordbox per performance sonore eccellenti
Search: scansione rapida all’interno di intere tracce con la jog wheel
Edit: cancella Hot Cue e campionamenti
NOVITÀ ESCLUSIVA: mixing remoto e controlli per effetti tramite remotebox per iPhone/iPad
I DJ potranno scaricare l’applicazione gratuita remotebox per iPhone, iPad e iPod touch (disponibile su App Store), per utilizzare i loro dispositivi portatili come telecomando per tutte le straordinarie funzioni dell’XDJ-R1. 1 Il sistema XDJ-R1 crea una rete LAN wireless privata per una connessione affidabile al dispositivo iOS.
I controlli tattili intuitivi comprendono browsing, caricamento e mixing delle tracce, oltre all’attivazione di effetti, Beat Loop automatici, Hot Cue e campionamenti. Inoltre – novità esclusiva nella gamma Pioneer – remotebox introduce l’innovativo XY Pad: uno strumento bidimensionale per lanciare e manipolare gli effetti Beat e di colorazione sonora, in combinazione.
Utilizzando remotebox su iPad/iPhone/iPod touch, i DJ saranno svincolati dalla cabina e potranno interagire di più, dare libero sfogo al loro talento e addirittura coinvolgere il pubblico nella scelta delle tracce.
Accessori su misura, facili da configurare e portatili
Il sistema XDJ-R1 “tutto in uno” racchiude tutto quello che occorre ai DJ in un’elegante unità integrata, dotata perfino di un pratico dock per iPhone/iPod touch, per tenere sempre sott’occhio lo schermo del dispositivo portatile. Infine, la robusta custodia DJC-SC3 (venduta separatamente) è studiata appositamente per l’XDJ-R1, con tasche multiple e una struttura verticale, che permette ai DJ di accedervi comodamente anche nello spazio ristretto della cabina.
Terminali di ingresso e uscita multipli per la massima flessibilità
Il sistema XDJ-R1 è provvisto di uscite MASTER (XLR), BOOTH, AUX e MIC, per la connessione di hardware esterni e sistemi PA professionali. Per questo, il mixer centrale può essere collegato a giradischi e CDJ e utilizzato come mixer indipendente.
Circuitaggio audio di alta qualità per un suono potente e cristallino
L’XDJ-R1 riprende la progettazione audio della gamma pro-DJ di Pioneer, compresa una scheda audio incorporata da 44.1 kHz/24 bit e una CPU ad alte prestazioni.
Altre caratteristiche:
Isolatore indipendente a tre bande con total kill
Doppia uscita cuffie ¬– mini jack per cuffie auricolari e jack standard per cuffie a padiglioni
Regolatori del volume per ciascun canale e uscita Master per rappresentare visivamente i livelli di segnale
Requisiti di sistema – DJ software rekordbox™ (incluso)
Sistemi operativi supportati Mac OS®X (10.5.8 o successivo)
Windows Vista® Home Basic/Home Premium/Ultimate/Business (SP2 o successivo)
Windows® XP Home Edition/Professional (SP3 o successivo)
(*Windows® XP Professional x64 edition non è supportato)
Requisiti di sistema – applicazione mobile remotebox™
Sistemi operativi supportati iPhone 3GS o successivo
iPod touch 3ª generazione o successivo
iPad iOS5 o successivo
Requisiti di consegna – VirtualDJ LE (download gratuito)
Sistemi operativi supportati (Windows) Windows® 7/Vista/XP (SP3) Intel® Pentium® 4 o AMD Athlon™ XP
Minimo 512 MB RAM
Sistemi operativi supportati (Mac) Mac OS X v 10.5/10.6/10.7
Intel® processor platform
Minimo 1024 MB RAM
Spazio su disco richiesto Minimo 50 MB
Risoluzione del display 1024 x 768 o superiore
Requisiti aggiuntivi per video mixing Scheda video ATI™ o NVIDIA® 256 MB DDR3 RAM video dedicati
P.S.: per tutte le altre informazioni potete scaricare il manuale del controller/console qui: http://pioneerdj.com/support/files/img/DRI1086A.pdf
e quello di remotebox qui: http://pioneerdj.com/support/files/img/DRI1115A.pdf
P.S.2: prima di fare altre domande tecniche sul controller o sul software fate almeno lo "sforzo" di dare una letta ai manuali... :geek: :ugeek: :geek:
geposted Fri 31 May 13 @ 7:49 am
Domanda tecnica: visto che viene dato in bundle con Virtual DJ LE, per i PRO User ci sarà un mapper da scaricare?!?
geposted Fri 31 May 13 @ 7:52 am
al solito credo che ci sara' un mapper da scaricare che verra' successivamente integrato nelle prossime versioni di Vdj.
geposted Fri 31 May 13 @ 9:01 am
djtntPRO InfinityMember since 2003
mi chiedevo una cosa... con la aero si può scaricare rekordbox per android che permette tramite il wireless di suonare i brani contenuti nel telefono. con questa consolle invece è stato rilasciato remotebox che può funzionare con la famiglia apple. Sapete se può essere utilizzata comunque con rekordbox androidiano?
geposted Sun 02 Jun 13 @ 11:28 am
Non è integrata la funzione Rekordbox wireless LAN .
geposted Sun 02 Jun 13 @ 2:29 pm
è un peccato...
geposted Mon 03 Jun 13 @ 4:02 am
cefadjHome userMember since 2013
Ciao ragazzi,
con xdj-r1 puoi collegarti con un pc normalissimo in wifi con recordbox?
una differenza con l'aero...non hanno messo il tasto per registrarti la serata, a me piaceva molto questa cosa, si può registrare con il recordbox nel pc?
altra cosa per remixare qualcosa da principiante cosa posso usare un cubase sarebbe adatto?
geposted Sun 09 Jun 13 @ 6:44 am
Wow! è davvero un gioiellino! :) Mi sono innamorato! In internet l'ho trovato a 965€. Qualcuno conosce qualche negozio fisico zona Brescia/Bergamo/Milano per poterlo toccare con mano? heheh
geposted Fri 14 Jun 13 @ 7:01 am
ciocePRO InfinityMember since 2004
Vai da Wimpy Music a Milano ;)
geposted Fri 14 Jun 13 @ 8:58 am
geposted Fri 14 Jun 13 @ 9:11 am
Oppure vieni a casa mia :-P
geposted Sat 15 Jun 13 @ 5:00 am
Salve, desideravo una piccolissima informazione che ancora non ho potuto trovare da nessuna parte, ma si può usare senza supporti esterni (iphone,ipad,ipod,pc o mac)? Si può usare per esempio come una normalissima consolle per pendrive e cd composta da lettori e mixer? grazie
geposted Wed 26 Jun 13 @ 7:30 am
6%
