Forum: Old versions
Topic: Freezing on loading songs
When i am playing on one deck and i go to load on the other virtual dj freezes for a few seconds and thats with 4gb of ram, how much ram do you need for virtual dj not to freeze or is it another problem? thanks
geposted Mon 03 Jun 13 @ 3:43 pm
ACER 8gb ram 750gb HD and i get little freezes everytime i load a song while the other deck is playing,CPU is barely ticking over so its not under pressure. i have VDJ 7.4 PRO and every so often since i installed it freezes and crashes. really annoying at this stage!!!!!!!!!!! use it with cdj 2000's and once a week with a numark djio. only running the one programme on the laptop (VDJ),dont put internet through it and ive everything i can possibly unistall and remove taken from the laptop any i only use the drivers which i need on the night and unistall the other so that eliminates any conflict that might arise thre. Any help or advice greatly appreciated
Also have a friend with the exact same laptop and settings and he has no problems at all....uses his with the denon mc6000 and pioneer cdj2000's
Operating system...?
Please register your Pro serial number to your account https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.)
VirtualDJ is very reliable for most users, so if you are experiencing these problems with the latest legitimate version of the software, then there is most likely an underlying problem with your system that needs to be found and resolved. Please see https://virtualdj.com/wiki/My%20computer%20keeps%20crashing%20or%20freezing.html
If you have not already done so, please also go through each step in https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html and ensure that your computer is fully optimised for DJ performance.
NOTE: If you are using an illegally downloaded version of VirtualDJ Pro, then this may be why you are experiencing these problems. Illegal pirate versions can be unreliable due to the illegal and unauthorised modifications that the pirates have made to the program. Illegal software can also be infected with viruses, spyware and other malicious software that can affect stability as well as security of your computer and your privacy. Also, if you are caught using illegal software and/or music in public at your gigs, then both you and your venue could face prosecution and a considerable fine.
