Is there any way to implement a way to toggle between stereo and mono in a future software build.For example I have a DDJ SX controller and like many other controllers the mixer section doesn't have a mono/stereo select switch.I've had occasions where I would have liked to run my system in mono ,because of speaker placement in the rooms or halls at certain functions.
geposted Tue 04 Jun 13 @ 10:35 pm
You can use the Advanced Sound Setup in Mono Mode and have e.g.
Master .. left ... DDJ SX ASIO ... Out 1
Master .. Right.. DDJ SX ASIO .. Out 1
but this has to be used prior start mixing. You can even save that Sound Setup and have different ones available using the Profile Switcher .. https://virtualdj.com/addons/12300/SBDJ_Profile_Switcher.html
geposted Tue 04 Jun 13 @ 10:59 pm
Thanks for the help
geposted Wed 05 Jun 13 @ 9:17 am
I tried to download the file and noticed it is an executable. I am running this software on a mac. Can you create a mac compatible version of this file? Thanks.
geposted Sun 12 Jan 14 @ 4:17 am
Any ideas for the DDJ-SZ???
geposted Sun 18 Jun 17 @ 2:07 am
I use SBDJs effect as master effect for this
Like this:
Like this:
I'm not so familiar with the SZ. It may bypass a lot of stuff and do it itself, so I'm not sure if it works with the that unit
geposted Sun 18 Jun 17 @ 7:15 am
Or you use a VST Plugin Effekt for this Stereo / Mono :
http://www.alexhilton.net/A1AUDIO/index.php/downloads
Greatings,Dirk
Greatings,Dirk
geposted Sun 18 Jun 17 @ 1:18 pm
Greatings,Dirk
Greatings,Dirk
when there is a hardware mixer like on the ddj-sz plugins on the master will not work since there is no master :-)
but this may work on the SX not sure.
geposted Sun 18 Jun 17 @ 1:23 pm
You can activate the VST Plugin Effects on the VDJ-Decks too.
hope that goes than by a hardware Mixer.
Have not test it so with my AA VMS2 Midicontroller but with
2x External SK with the VDJ 7.4.7 Pro Basic or VDJ 8 Pro Legacy that goes too.
greatings,Dirk
greatings,Dirk
geposted Sun 18 Jun 17 @ 2:27 pm
Yes, it works when you use the effect in one of the effect slots on both decks
Just remember to disable "resetFXOnLoad" in the settings
Like this
geposted Mon 19 Jun 17 @ 8:27 am
