Does anyone know if there is a way to map VST settings or get VST settings I change to reload the settings on VDJ launch? A ini file is created in the effects folder but I have tried editing it to make it load manual settings without success. I know you can change VDJ plugin settings to map to buttons etc but how do you do it for VST's with knobs and flip switches etc?
geposted Wed 05 Jun 13 @ 10:40 am
