Forum: Old versions
Topic: Both decks are playin on one output
Hi Guys,
I just received the American Audio Versadeck with Virtual DJ LE package. Deck A is alright but deck B is playing on same channel as deck A, so the volume fader of deck A effects both decks.
Could not find any channel setup for Virtual DJ.
Can anyone assist me please?
Thanks
KC
geposted Thu 06 Jun 13 @ 3:56 pm
On most LE versions you can't adjust something and so it is needed to setup the driver and also setup of the controller in a propper manner.
http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1458
Install the latest driver and check the manual how to setup the controller.
I'm sure this will help you to fix teh problem.
Only while using the pro Full you will need to adjust something inside VDJ.
Please keen in mind when you like to upgrade to Pro Full in the future, wewill offer you a discount.
Just insert your VDJ LE serial at >> Upgrade to VirtualDJ Pro Full << and press continue.
https://virtualdj.com/buy/
I am having the same problem and I have the full Pro version so it is nothing to do with only having a demo version.
I reinstalled the latest Versadeck drivers several times (full reboot and reload of Virtual Pro etc) but the problem persists. Does anyone know how a solution to this
