paidia xrisimopoiw to sygkekrimeno set ena xrono xwris kanena ousiastiko provlima. tis dyo teleftaies meres otan kapoia stigmi anevazw entasi o ixos kanei diakopes kai paramorfweis. otan xamilwnw ola kala. ti mporei na symvainei kai giati synevi xwris na yparksei kamia allagi se tipote (oute sto pc, oute sto programma, oute stin karta ixou). yp'opsin oti ekana oles tis aparaitites allages se kalwdia, 8yres usb k.l.p.)
geposted Sun 23 Jun 13 @ 2:00 am
den gnwrizei kaneis ti mporei na symvainei?
geposted Tue 25 Jun 13 @ 6:21 am
Kata pasa pithanotita, auto ofeiletai eite se poly xamilo ASIO latency eite se kako stisimo tou ypologisti sou.
Dokimase na anevaseis to latency (buffer) apo to Control Panel tis kartas ixou kai des an ta kopsimata stamatoun.
Yparxei periptwsi ta kopsimata - paramorfwseis na erxontai apo to PA systima ? Dld na yparxei kapoios kakos compressor pou na dimiourgei auta, i paramorfwsi na vgainei apo ta idia ta ixeia (na kovei o enisxytis klp) ?
geposted Tue 25 Jun 13 @ 8:22 am
Yparxei H pithanotita , epeidi mou eixe symbei kai emena , xoris na ksero ti set douleveis , na ftiane ta plato , ta jog whells tou controller.
Gia paradeigma emena , ginotane , ama eixa kai kanena monitor , gyrismeno se mena gia na akouo , H kapoio Hxeio genikotera.
Xamilosa apo gonfic > epiloges tin eyaisthisia ton jog wheels sxedon sto 10% , kai den eixa ksana to idio provlima.
Isos kai ayto pou leo na min exei kapoia sxesi me to diko sou provlima , apla to anafero mpas kai yparxei lisi.
geposted Tue 25 Jun 13 @ 5:41 pm
Oxi Gianni, to provlima pou eixes den epireazei tous controllers me touch sensitive platters, alla mono autous pou einai motion sensitive i pressure sensitive.
geposted Tue 25 Jun 13 @ 5:53 pm
Mpampi den leo gia to provlima pou eixa me tin reloop beat mix , (pou xrisimopoio mono gia tin ekpompi) , kai pou den ksekinouse to ena plato , anaferomai stin numark dmc 2 , (pou xrisimopoio san standard set mou) , kai sta mikra Mayra rodakia tis pou mallon epireazontan , apo tin entasi , opos eipa parapano , kai eixan ginei kapoia mikra kopsimata ston ixo , kai den mou to ekane ksana , otan ta piga sta 10% peripou.
Bebaia pleon sto search omos , theloun pio polla gyrismata.
geposted Tue 25 Jun 13 @ 7:19 pm
Ποιο set ???
Πέρα από τις προτάσεις των παιδιών θέλω να σε ρωτήσω: Για πόση ένταση μιλάμε;;;
Είχα πρόβλημα σε ένα μαγαζί που όταν ανέβαζα ένταση είχα συχνά πυκνά μικροδιακοπές στον ήχο. Μετά από αρκετό ψάξιμο και αρκετό προβληματισμό βρήκαμε οτι έφταιγε το booth! Το σημείο που τοποθετούσα το laptop συντόνιζε πολύ εύκολα με το sub με αποτέλεσμα οι κραδασμοί να ενεργοποιούν την λειτουργία προστασίας του σκληρού δίσκου του laptop. (Μιλάμε για DPC της τάξης των 5msec!!!)
geposted Fri 28 Jun 13 @ 3:09 am
Giwrgo, diakopes ston ixo den dikaiologontai apo ton Skliro disko. To tragoudi einai fortwmeno sti RAM
geposted Fri 28 Jun 13 @ 12:33 pm
Κι όμως...
Το Toshiba που έχω έχει ένα anti-shock HDD protection utility.
Όταν το laptop λαμβάνει δονήσεις - απότομες κινήσεις πάνω από κάποιο threshold τότε το laptop αυτόματα "μαζεύει" τις κεφαλές των δίσκων στη θέση park.
Όταν συμβαίνει αυτό δεν έχει σημασία αν το τραγούδι είναι ήδη φορτωμένο στη RAM ή όχι. Όπως είπα παραπάνω, εκείνη την στιγμή το utility δημιουργεί ένα DPC Latency που φτάνει και μπορεί και να ξεπερνάει τα 5milli-second!!! Τα κοψίματα στον ήχο μου τα έκανε από buffer under-run και από DPC Spikes.
Σίγουρα μικρές δονήσεις δεν επηρεάζουν το σύστημα του, αλλά αν έχει κοντά κάποιο sub, καλό θα είναι να το τσεκάρει και αυτό...
geposted Fri 28 Jun 13 @ 12:51 pm
μήπως έχει πάθει τίποτα κάποιος ενισχυτής? τσέκαρε από τα φαν αν κάποιος βγάζει πιο ζεστό αέρα...πολλές φορές αυτό γίνεται λόγο ασφάλειας για να μην καεί κλπ..
geposted Mon 01 Jul 13 @ 4:30 am
Σε αυτή την περίπτωση (υπερθέρμανση ενισχυτή) ο ενισχυτής Α μειώνει την απόδοση του και Β κλείνει για προστασία μέχρι να κρυώσει σε πιο χαμηλά επίπεδα θερμοκρασίας εντός των προδιαγραφών ασφαλείας που έχει. Συνήθως αυτή η διακοπή διαρκεί από μισό μέχρι και πέντε λεπτά. Είμαι σίγουρος οτι ο φίλος μας όταν λέει διακοπές δεν εννοεί τόσο μεγάλες διακοπές για να υποπτευτούμε υπερθερμασμένο ενισχυτή...
geposted Mon 01 Jul 13 @ 5:03 am
σε περίπτωση που ενισχυτές είναι συνδεδεμένοι σε crossover (αυτό πολλοί το κάνουν όταν υπάρχουν ξεχωριστές γραμμές ηχείων και δεν θέλουν να παίζουν όλα ή άλλα να τα έχουν για live κλπ) το κάνει για δευτερόλεπτα....
τεσπα εγώ το λέω γιατί πολλές φορές απλά πράγματα δημιουργούν τα μεγάλα προβλήματα... ;)
geposted Mon 01 Jul 13 @ 7:22 am
