thanks 4 the mix track pro 2 skin downloadlink guys. Nice!!!
geposted Wed 21 Aug 13 @ 1:48 pm
maybe you guys should add on the song list option, displays of both decks A&B because you can't see the info of the song that is playing. That would be nice.
geposted Wed 21 Aug 13 @ 1:56 pm
NICE! I will download when I get home from work today.
I was waiting for a sweet little skin for the MTP2.
geposted Mon 26 Aug 13 @ 11:38 am
how can i download it??
it says i dont have permission or something like that...
nvm i didnt read something
geposted Sun 22 Sep 13 @ 7:03 am
Please read our FAQ pages:
http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
geposted Sun 22 Sep 13 @ 10:56 am
Norton 360 is claiming that the skin for mixtrack pro II is NOT safe and is deleting the file when downloaded.....anyone know anything about this?
geposted Mon 30 Sep 13 @ 6:10 pm
Norton will probably say that for every skin you try to download. Definitely every single Plugin from our Download pages is 100% safe to download and install. Norton (among other antivirus softwares) faulty detect several files as unknown threads, trying to protect your computer.
Usually, there is an option to allow/run anyway, maybe hidden under an icon or a "More" option.
Alternatively, you can temporary disable your Antivirus, install the Plugin/Skin and enable afterwards.
geposted Mon 30 Sep 13 @ 6:42 pm
Hello.I want to donwload the skin for mixtrack pro 2,how ican this
geposted Wed 23 Oct 13 @ 9:20 am
You need to be a registered licensed user.
Please read this : http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
geposted Wed 23 Oct 13 @ 11:25 am
can someone please help me to be able to use my mixtrack pro 2 with virtual dj
geposted Fri 27 Dec 13 @ 3:40 pm
If you have problems with the controller then you need to explain why it's not working in the first place. Also if this is the case you shouldn't be posting in a forum about the skin for the product. I suggest looking here: http://www.virtualdj.com/forums/140684/PC_Version_Technical_Support/Numark_Mixtrack_Pro_problems_.html?search=mixtrACK%20PRO%202&page=1
This is a link to the original version but it might be able to help. If it doesn't the please use the search function on the forum or start a new topic in an appropriate thread.
If your trying to access this skin then please read here: http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
Thanks
Thanks
geposted Fri 27 Dec 13 @ 4:00 pm
oi boa tarde comprei uma mixtrack pro II mais nao consigo usala no dj virtual no meu notebook. me ajude pelo amor de Deus.
geposted Mon 13 Jan 14 @ 11:58 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
geposted Mon 13 Jan 14 @ 12:23 pm
Hello, first congratulations for the great and beautiful job you did.
Second, it could do so at 1280x800 resolution?
I tried to convert the tool provided by Virtual, but was buggy.
Grateful.
Hugs.
Grateful.
Hugs.
geposted Thu 06 Mar 14 @ 5:46 pm
Try to use the 1440x900 with the Resizer tool and Simple Resize Option. Normally, it shouldnt be a problem to get a 1280x800 skin resolution.
geposted Thu 06 Mar 14 @ 9:24 pm
J'aimerais avoir un skin de numark mix track pro 2 pou mon virtual dj
geposted Thu 13 Mar 14 @ 11:18 pm
geposted Fri 14 Mar 14 @ 6:30 am
Lovely skin Bob! Thanks djDAD.
There's a minute error on xml file regarding the LED of DECK2 vinyl mode, though it doesn't affect the functionality but could be confusing to the user. Corrected mine and a pretty easy task if a user knows what to do.
geposted Thu 10 Apr 14 @ 1:45 am
PARA LOS QUE TODAVIA SE PREGUNTAN COMO PONER EN FUNCION SU CONTROLADOR NUMARK PRO 2 ES MUY SENCILLO SOLO DESCARGUE EL PLUGIN DE LA PAGINA DE NUMARK Y LUEGO UN TUTORIAL DE COMO MAPEARLA EN GOOGLE Y SERA MUY SENCILLO
geposted Sun 27 Apr 14 @ 11:47 pm
geposted Mon 28 Apr 14 @ 6:43 am
