Forum: Old versions
Topic: numark n4
so i have numark n4 and my vdj le has expired already!! so now i have vdj pro and i want to use it with my n4 but i cant connect it dont let me use vdj pro with numark n4!! i will like to have some help with this!!!
geposted Sun 30 Jun 13 @ 10:06 pm
Even if the 20days of Pro Full Trial Period has ended, your LE version should still work, but of course with the features of the Limited Edition.
If you have upgraded your Le version to Pro full , please register your Pro Full serial number to your account https://virtualdj.com/users/edit.html and download the latest available Pro Full version from your Download Center.. https://virtualdj.com/download/updates.html
i know my vdj le works! but i dnt know why vdj pro doesnt recognize my n4! and i already upgrade everything!!!
thanks 4 the help!!!
I just bought the Numark N4..It came with the Virtual DJ limited edition. However I cannot hear the cue on any of the 4 tables in my headphones..It works just fine with the Serato intro software which has 2 tables. Can someone please tell me what the problem is?
you need to go to the settings and select Inputs: None
Outputs: Headphones
Sound Card: ASIO or 4 out (MacBook) then make sure it says N4 in the drop down tap.........Works flawless for me
ASIO drivers are not available for the Numark N4 device and ASIO4ALL is not recommended.
Please follow the recommended Sound Setup
https://virtualdj.com/wiki/N4.html
Also make sure the N4 sound card is set to Quadrophonic mode (4 speakers) from the Windows Sound Configuration (Playback devices)
Thanks for the help.
