Hey guys i lost my power adapter and i need the exact specs of the adapter to order a new one. Please take a moment and tell me what the adapter specs are such as voltage, ma and every information that ison it.
Thank you!
Thank you!
geposted Tue 16 Jul 13 @ 10:41 am
I looked at mine and it doesnt look any different than a printer cable that can be found at electronics store. I think as long as its a 2.0 USB cable it should be fine.
geposted Tue 16 Jul 13 @ 4:16 pm
Oops. I just noticed its for the rmx 2...
Discard
Discard
geposted Tue 16 Jul 13 @ 7:19 pm
@Klubbheads
Contact Hercules Technical Support. They'll be able to provide you with a replacement power supply.
http://ts.hercules.com/eng/index.php?pg=contact
geposted Wed 17 Jul 13 @ 5:59 am
does anybody know where i can get a replacement power adapter for a Hercules RMX 2?
geposted Mon 11 May 15 @ 10:41 am
I guess you didn't read the last message of this thread before posting your own, didn't you?
geposted Mon 11 May 15 @ 2:45 pm
Does anyone have the response for the OP? As in the stats needed.
I see the response from hercules, yes I can read... so before you reply that I cant keep your comments to yourself.
I would like the STATS, not a link to an email support team.
geposted Tue 26 May 15 @ 2:35 pm
Sorry if you felt offended by my reply, that was not the intent at all.
And as for the power supply specifications, although they are clearly printed on the back of the Rmx2 (right atop of the connector), here they are for everyone's benefit:
7.5V /1A - Center positive
geposted Wed 27 May 15 @ 6:45 am
Hello - I'm looking for the tip dimensions for the RMX2 power supply. While there seems to be tons of 7.5V /1A - Center positive power supplies available, there are equal amounts of different tip sizes.
geposted Thu 15 Sep 16 @ 5:03 pm
The DC connector will accept both 2.0 and 2.5 mm plugs.
geposted Thu 15 Sep 16 @ 5:15 pm
Dj Phatso Thanks!
geposted Thu 15 Sep 16 @ 5:53 pm
Mine came without one but luckily I had a compatible one from an old router. Would be nice to have the breakout version that goes with it though.
geposted Fri 16 Sep 16 @ 1:11 am
