I recently picked up a pair of Numark V7's and got them set up with Virtual DJ. I am getting periodic 'popping' noises from the audio output of the V7. Here are the details of my setup:
- VDJ latest version 7.4
- V7 ASIO selected as output device
- Deck 1 Outputs 1 & 2 --> Numark V7 "Deck A" RCA Outputs
- Deck 1 Ouputs 3 & 4 --> Numark V7 "Deck B" RCA Outputs
Laptop:
Windows 7 Home Premium 64-Bit
Intel i7-720qm Quad Core @ 1.60GHz
4GB DDR3-1600 Ram
I've checked that the issue isn't something else (corrupt MP3's, amp, speakers) by using my laptop's sound card and headphone out jack. When I did so I didn't hear any of the popping noises.
Just last week, using my Numark Mixtrack Pro, I was not having any problems. Aside from my audio output settings, I have not changed any other settings. None of my other gear has changed, either, except I'm using a Numark M6 mixer. I hooked other audio sources up to it and it doesn't seem to be introducing any noise itself.
Does anyone have some troubleshooting suggestions or potential fixes?
Laptop:
4GB DDR3-1600 Ram
geposted Mon 22 Jul 13 @ 9:52 am
Usually this is a sign that your ASIO driver latency is set too low. Push it a notch higher and try again.
If you're not aware, the system requirements on the Numark site state that a 2.4GHz CPU is the minimum on Win 7 64.
On a 32 bit system it's only 1.8GHz.
geposted Mon 22 Jul 13 @ 11:27 am
Well, the site says 2.4 GHz Core 2 Duo. The i7 is a significantly more powerful processor despite the lower clock speed, with double the listed L2 cache (6MB).
I suppose, though, if the audio is relying on a single-threaded process, the lower clock speed could possibly be an issue.
I'll try adjusting the latency and see if that helps, thanks.
geposted Mon 22 Jul 13 @ 12:53 pm
As far as I'm aware, the way I understand it is that things always work on a single core until that core can no longer cope, at which point the second core is brought into use, and so on.
geposted Mon 22 Jul 13 @ 1:45 pm
No matter how strong your computer is, you still need to optimize it for best performance. Please see here.. https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
This tool might also do the job.. https://virtualdj.com/addons/16006/VirtualDJ_PC_Optimizer.html If not, then you must follow the hard path ;) as above.
geposted Mon 22 Jul 13 @ 6:21 pm
I set the latency as high as possible and even checked "safe mode.," and still got the pops. I'll try the tweaks in the guide above to see if it helps. I do know that the green CPU meter rarely exceeds 20% or so, and I've never seen it past 1/3. I suppose it could be pegging one of the individual cores, in which case it might still only read 25% on the meter.
I'm just surprised I'm having problems since I never had any with the same system using my mixtrack pro in place of the V7's.
Tried Serato Itch, no issues with playback in there.
geposted Tue 23 Jul 13 @ 3:57 pm
Have you tried this:
Quote :
The DPC Latency checker can be used to check for performance issues with your computer: http://www.thesycon.de/deu/latency_check.shtml
If your computer has DPC latency issues (Red spikes or high yellow ones), then LatencyMon (Windows Vista or 7 only) can help you identify the processes that are causing the problem: http://www.resplendence.com/latencymon
geposted Wed 24 Jul 13 @ 6:35 am
So with everything else the same, just running Itch instead of VDJ, it works fine?
Are you using a VDJ skin that's the same as your screens native resolution?
Are you using the scratch waveforms/coloured waveforms?
geposted Wed 24 Jul 13 @ 7:17 am
Do you see any improvement in performance if the motors are turned off ?
geposted Wed 24 Jul 13 @ 6:40 pm
Hey guys, sorry for the delay in posting back.
At some point my skin got changed to one that was a higher resolution than my laptop's screen, as groovindj mentioned above. I changed it back, but its still didn't solve the issue.
What DID solve the issue was switching from "advanced stretching" to "Pure Scratch." I should have changed it ANYWAY because the primary reason for going to the V7's is that I'm getting better at scratching so I wanted better gear (my bad!)... but regardless it fixed the popping noise that would occur when I was just playing tracks and not scratching.
Thanks everyone for the help and input and I hope this thread can help someone else in the future!
geposted Thu 01 Aug 13 @ 1:08 pm
Bumping my old thread here...
The problem with my "solution" above is that, if I want to use my V7's for mixing EDM or something else where I DO want Master Tempo, I don't currently have a solution. How do I use master tempo without the pops/distortion? Any ideas?
I'm pretty sure my system is as optimized as possible (wifi turned off, background processes killed, etc etc). Like I said originally, I have no issues mixing with Master Tempo using my old Mixtrack Pro...
geposted Thu 24 Oct 13 @ 2:08 pm
