Hello,
i was preparing a new backup-machine for my VDJ-setup and ran into problems with ASIO.
After installing the most recent Denon ASIO-drivers for my MC6000 and also installing Virtual DJ, I wanted to configure the MC6000 in VDJ.
I can select the ASIO drivers there, but when applying the settings, or restarting the program I get this error : [Error in the ASIO sound driver: Your soundcard is probably not connected, or the settings are incorrect.]
Disconnecting/connecting the Denon Controller, restarting the PC, nothing helps.
In the Denon ASIO window, the controller appears.
And for a test I've installed also Traktor, and this is working correctly with the MC-6000 in ASIO mode.
So what could be wrong ? Any hints or suggestions ?
grtz
Patrick
grtz
Patrick
geposted Thu 25 Jul 13 @ 3:07 am
Make sure you follow the correct Setup, according to the decks you wish to use .. https://virtualdj.com/wiki/DN-MC6000.html
geposted Thu 25 Jul 13 @ 4:06 am
On my Denon Dn-Mc6000 i cant hear the left channel. Wont play on the controller. Anyone know why?
geposted Thu 22 Sep 16 @ 4:48 am
Did you read the link above? What are your soundcard settings?
geposted Fri 23 Sep 16 @ 11:25 pm
