Greetings All,
Does anyone experience this? My Pioneer ddj sx is having midi interference issues. If I touch volume levels 1 or 4 it lowers my volumes on 2 & 3 even when 1 & 4 are not set to pc. If I want to raise my mic level on volume fader 1 it will immediately lower my volume level on fader 2. If I have an analog input on volume level 4 as soon as I touch level 4 it will lower volume level 3 :-(. now keep in mind I only use two player mode skin and use my other 1 & 4 faders for analog stuff like my mic and analog audio inputs. Please help I was thinking about going into the mapper and deleting volume faders 1 & 4 do you think this will help? This issue happens on all of my laptops. I also refer to this problem as midi bleeding ?
Thanks,
Keivan Keihani
Preferred DJ's
Thanks,
Keivan Keihani
Preferred DJ's
geposted Tue 30 Jul 13 @ 3:16 am
This may be because you are using a 2 deck skin, which will cause decks/channels 3&4 to wrap back around to 1&2. The native mapping is designed for use with 4 decks.
Either use it with a 4 deck skin or download the updated mapping from the following page: https://virtualdj.com/addons/15822/Pioneer_DDJ-SX_%28Native%29.html
geposted Tue 30 Jul 13 @ 4:10 am
Awesome! Thanks for the quick response. I will try this immediately :-)
geposted Tue 30 Jul 13 @ 4:25 am
That suggestion worked 100%.
Thanks Again :-)
Thanks Again :-)
geposted Sat 01 Feb 14 @ 4:07 am
